'03 s60 needs good engine shop
- Has thanked: 311 times
- Been thanked: 817 times
WD-40 is completely useless as a penetrant, it will not help at all. PBBlaster or Liquid Wrench sure, or homwbrew acetone + ATF etc.
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Yeah. I’ve hammered that thing with PB and my impact that thing isn’t budging. I guess I’ll just have to deal. I have one last ditch effort.
I was thinking oil coolant fill drain refill the beautiful milky sludge of coolant and oil mix!!!’ Ole!
Thank you for your help. I need this car out of my garage so I can get another one back in. Geesh.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Been thanked: 4064 times
I crack the crank bolt off before Removing the timing belt, using a 1/2 inch impact rated at about 550 ft lbs
stephansvolvo
I’m not sure my little 1/2 inch has that much torque. I tried everything.abscate wrote: 15 Apr 2021, 04:40 I crack the crank bolt off before Removing the timing belt, using a 1/2 inch impact rated at about 550 ft lbs
I remember reading that from your recommendations. Is it lefty loosey?
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Are you using an impact socket? The thinner wall regular sockets don't transfer as much impact force. They even make a super thick wall socket for Honda crank bolts (won't fit Volvo crank nut though), which are very difficult to remove even with the strongest impact wrench.stephansvolvo wrote: 15 Apr 2021, 09:17I’m not sure my little 1/2 inch has that much torque. I tried everything.abscate wrote: 15 Apr 2021, 04:40 I crack the crank bolt off before Removing the timing belt, using a 1/2 inch impact rated at about 550 ft lbs
Along those lines ... I don't know if it's in the budget but this cheap-o corded tool would outperform a typical home air tool setup costing much more and probably be the last impact you ever needed, assuming you don't have to get into tight places with the tool https://www.harborfreight.com/85-amp-co ... 64120.html
I've got one with less torque that has never met an axle nut or crank nut it couldn't spin off. I basically use my air gun until it gets overmatched then get out the electric one for those one or two stubborn fasteners.
- 543 Views
Last post by hermechanic
- 1013 Views
Last post by BRxc90
- 1861 Views
- 590 Views
- 602 Views
