Wiper Linkage Plastic Ball Socket Retainer
zupta82
- Year and Model: 1995 960
Hello, I am having trouble finding replacement black plastic retainers for the wiper linkage. The arm for the driver side keeps popping off. I don’t really want to buy a whole new transmission.
- Has thanked: 311 times
- Been thanked: 817 times
Looks like an 850 from the engine bay, is that right?
Most on here rarely look at the front wiper linkage. I'm having a hard time understanding what part are you looking to fix or replace, though maybe someone else can tell.
- RickHaleParker
- Been thanked: 977 times
The Ball and Socket joints rarely wear out.
It looks like the problem is the bent drivers side linkage arm. The bend would shorten the arm. The increased tension would cause the Ball and Socket joint to pop apart. The linkage arm need to be the correct length and geometry. Too short, it will pop off. Too long, it will pop off. If the Geometry is off, it will pop off.
You can pull a whole Wiper Transmission from a self service junk yard for ~$15.00 and some Elbow grease.
Active
Past
Past
- 650 Views
Last post by Caffeind
- 373 Views
Last post by ychao
- 82 Views
Last post by DennisCA
- 844 Views
Last post by ZionXIX
- 577 Views
Last post by Sommerfeldt
