Re-attaching wheel well plastic sheet
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Hi Guys.
A little while ago I had asked a question about why my sunroof would no longer open and someone here stated that usually it means that the alarm system has some corrosion of sorts near the plug for the alarm which is located near the passenger side wheel well on my 2002 V70 (P2).
My question is do I need to pick up at a dealer those small press-in type clips that hold the plastic sheet back up into the wheel well
after I disconnect the alarm plug? I have not jacked up the car yet to look at what I need to do. Thx in advance!
Has thanked: 1506 times
Been thanked: 3821 times
Mr. Detail wrote: 29 Apr 2021, 08:06 Hi Guys.
Try this part number
8687663
..with my friends Scott and Nick at FCP Euro
These are hard to find on the Volvo webstore - buried in the Mudflaps section.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
they come apart in two pieces, the centre pin and the body then you can re use them, just tap/punch out the centre with a nail or punch. Volvo use them in a host of different places, ive got a bag of them i have removed from my junkyard car.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
I use pop rivets if needed.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I did remove only the rivets needed - I think 3 -4 of them, and didn't put anything back, it stays well. Otherwise, if you have a junkyard, remove some plastic pins from the cross member above the radiator
Mr. Detail
Thanks much guys! I did not know they could be "re-used".
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
If you get to the alarm siren through the bumper and passenger light it is much simpler, plus you don't need to rivet anything.
Mr. Detail
vtl, how do i do that? maybe I can do ti myself. Do I have to remove the actual bumper? I need to get that darn amlarm unplugged so my sunroof will work again. It's getting warmer now.
vtl
Post by vtl »
(on my 02 V70 bumper removal was a bit different, haven't had to remove that trim piece)
Mr. Detail
vtl, I can't view those photos or picture snapshots you sent. Just blank.
