'07 S80, 3.2, 110k - P0306, P003F Diagnostic Assistance Welcomed
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
IronMike
Year and Model: 2007 S80 3.2
Has thanked: 5 times
Been thanked: 4 times
Post by IronMike »
I've had many Volvo's with the 5 cylinder and a Bertone 262 with the PRV6. The 3.2 is new to me and I've done some of the basic engine maintenance on the XC60's 3.0 and my other S80's 3.2. You may remember me from the issue I have about 1.5 years ago where the engine shut down due to the bad tensioner bearing/water pump belt which is common for these engines. That was about 10k miles ago and that repair went well, thanks to Mr. Gill . During this repair I:
- Did a compression check and all were within range
- Scoped the cylinders and all looked rather well
- Put in new plugs
- Installed new valve cover/PCV
- Cleaned throttle plate
- Replaced the coolant reservoir which seemed to be dribbling
Started it up and drove it with great anxiety, yet it ran like a dream. Drove it for much of 2020 and ran really well, extremely smooth engine. About 6 months ago, went for inspection and failed due to crumpled exhaust connector pipes between catalytics and exhaust on both sides. Ran fine otherwise, go figure, didn't even really sound loud! Replaced entire system for $1000. Oh well, was worth keeping running after that major PITA effort to replace that belt the year before ;)
Since then the car has been running extremely well again. Actually I've grown to like these luxury models and a joy to ride on the highway. Up until last week, hence this topic.
Started it up one morning and it seemed to be idling uneven/lumpy. Not at all like it was, which was ultra smooth. I opened the hood and disconnected each coils connector in turn and each one cause detriment to the idle so seems like this isn't an ignition misfire in the traditional sense. I get the feeling that "misfire" has a more generalized definition in Sweden ;-) - as in "something didn't work which caused a delay in cam getting to correct point as predicted by ECM". This could be injector issue so I did the same with the injectors and in turn each one made the idle much worse as I removed it. Sigh, was hoping for some diagnostic gold here.
Closed the hood and as I drove it seemed to get better and smooth out. Within 2 miles the idle smooth and things seemed normal. Same thing happened the next day, ugh. Figured maybe gas, temperature (it was freezing out) or... ???? Then, on the highway I accelerate hard to merge (these cars are quick!) then settle into the lane around 65mph and suddenly feel a "hiccup" as if there's a misfire. Then the Check Engine light comes on (who doesn't hate THAT?). Car was running OK, not as smooth and bit of a hesitation from stops. But I kept going and when I got to my destination pulled out my iCarsoft scanner from the trunk, which I was oddly excited to finally use for diagnostic purposes!
Pulled code P003F (intake VVT solenoid stuck) and P0306 (Misfire cylinder 6). Cleared the codes and same ones keep coming back. Pulled the VVT Solenoid out and cleaned it and the rubber o-rings were both in bad shape, esp. the bottom gaskety one which tore while I was putting it back on. So, I ordered a new VVT solenoid since clearly this one was from 2007 and the o-rings don't seem to be available individually. Checked the wiring and all looks well. The coils look original but in good shape and I will probably replace them just due to age). Installed the new solenoid. Erased the codes and also disconnected the battery. Reconnected the battery and fired it up.
Still started with lumpy feel and then the codes still return after driving a while. Guess it wasn't just the solenoid?
I swapped coil 6 with coil 2, cleared all the codes, etc. Drove it that next day and same codes come back. So maybe not the coil itself giving P0306.
What would you do next?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
IronMike wrote: 04 May 2021, 09:01 ...thanks to Mr. Gill.........
- Put in new plugs
Mike,
I appreciate your acknowledging my help and I will try to help more
Here is what I would do. (in this order)
1. Swap the VVL (Variable Valve Lift) solenoids the one on the right controls 3,5,6 and the left controls 1,2,4
--- would do this even if it means that yo are swapping the part you replaced
------ I prefer know good vs. new
2. Remove and inspect spark plug number 6 (is it covered in oil? post pictures here)
--- I assume that you are using DENSO Iridium 4704 at the stock .040" gap (if not get one and install it in #6)
3. Reset the codes and drive with the dipstick lifted to release any combustion gases into the engine bay
--- this will bypass the PCV and allow you to test the rest of the engine
----- drive the same place that set the codes before
4. Swap injectors #6 to 1,2 or 4
5. Clean the MAF
6. Replace the fuel pressure sending unit
Start there and let us know.
Take care
Mr. Gill
pgill
Post by pgill »
Here are the parts that I am recommending that you swap
And these parts should look like this
If you removed the Variable Valve Timing instead of the Variable Valve lift then it will look like this
If this is the part that you removed and you need O-rings then get the Land Rover O-rings (they should work fine)
LR003093 for the bottom O-ring
I don't have a part number for the other O-ring
Take care
Paul
IronMike
Post by IronMike »
Hey Paul,
The full code was ECM-P003F00 Intake (A) Camshaft Profile Control Stuck On (Bank 2). I replaced the single long VVT, which I believe is the correct one?
IronMike
Post by IronMike »
Dude, I replaced the wrong one didn't I. :(
IronMike
Post by IronMike »
pgill wrote: 04 May 2021, 13:11
Mike,
THANK YOU! I've come to really like driving this old graceful model :)
Will do!
Bought new pack of plugs, will replace them anyway even though they only have 10k on them. You never know and not a big investment and going to pull them anyway. I got those exact plugs and will careful check gap before installing. Interesting to note that when I bought the car with 100k on it, I replaced the plugs and filters to get a baseline. The old plugs were the wrong ones! They were the ones for the previous years which had multiple grounding electrodes for each plug.
Great advice, thanks.
Sounds non-trivial on this old car. Should I buy new seals if I'm going to pull the rail?
5. Clean the MAF
Done!
Will do!
Will do!
Take care
Mr. Gill
THANK YOU!
IronMike
Post by IronMike »
Confirmed I replaced the wrong one. Was led astray by another poster in another thread/site along with the Carsoft code referencing the "Intake" so I focused on that other intake solenoid. Just removed the smaller one next to it and was total crap ;-)
pgill
Post by pgill »
Mike,
You are on the Path.
Just keep us informed of your progress.
Take Care
Paul
IronMike
Post by IronMike »
Purchased two of the Doorman versions and replaced them and car runs great again. Thanks!
