bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 31 May 2021, 21:14 Correct onthat, bdub
That’s what I thought, the starter signal is the only thing that the PNP switch should affect.
mdr, when you said you got a cough, do you mean it’s cranking and trying to start, or it only briefly cranked? I would only suspect the PNP switch if you’re experiencing the latter.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
bmdubya1198 wrote: 31 May 2021, 20:36 The PNP switch would cause a no crank though, not a crank no start. Right?
He did not say it cranks, he said it coughs. Completely out would be no crank. Just poor contacts might let it cough as Mdr puts it.
Regardless, Mdr now has enough information to confirm or disprove his analyst. If he can take the information and apply critical thinking. If he is incorrect he still has enough information to finish trouble shooting.
Has thanked: 1503 times
Been thanked: 3817 times
Threw the Battery switch on Shaggkira to mitigate current drain. I have a tailgate light that sticks on and runs the battery down, have to hunt down the switch or wiring fault.
It’s not the best solution because disconnecting the battery is runn8ng the fuel map cold but so goes the war.
bmdubya1198
RickHaleParker wrote: 31 May 2021, 23:48 He did not say it cranks, he said it coughs. Completely out would be no crank. Just poor contacts might let it cough as Mdr puts it.
Well I hear "cough" and I assume it's cranking and sputtering. Obviously terms like that are subjective, so it's best to confirm lol.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 01 Jun 2021, 05:07 Threw the Battery switch on Shaggkira to mitigate current drain. I have a tailgate light that sticks on and runs the battery down, have to hunt down the switch or wiring fault.
And about those headlight wipers...
Gives the car that quizzical eyebrow look. (Or an evil frown.)
foggydogg
Post by foggydogg »
mdr1220 wrote: 31 May 2021, 13:24 I'm a idiot but a Volvo would do that to you. Thought I had lawnmower syndrome went through the steps to correct it and it still wasn't working. So I was digging around in the help section here and after eliminating all the usual suspects, endedIMG_20210531_151134345.jpg up with this. The neutral safety switch. This has to be it because this looks like it's oe and I did the shifting back forth and only got a slight cough from the engine when I turned the key.
One trick that helped me solve a mystery electrical gremlin on my first 850 was to unplug and re-plug the coolant sensor a couple times. Maybe the Crust of the Ages has gummed up the spades. You're already looking at the module anyway.
mdr1220
Year and Model: 1996 850R
Has thanked: 44 times
Been thanked: 7 times
Post by mdr1220 »
foggydogg wrote: 01 Jun 2021, 12:39
It was not visible before I cleaned it. When I got this it had 193k on it with a documented timing belt change at 157k. Idles perfectly at 900 but everything around it needs replacing. Still has the original alternator and that's next on the list to go.
Used to have a 01 c70 convertible
RickHaleParker
bmdubya1198 wrote: 01 Jun 2021, 10:11 Well I hear "cough" and I assume it's cranking and sputtering.
In association with a engine I would have the same interpretation.
In association with the starter, my interpretation is the starter moves a little then quits.
RickHaleParker
mdr1220 wrote: 31 May 2021, 13:24 I did the shifting back forth and only got a slight cough from the engine when I turned the key.
Have you checked and cleaned the battery terminals? Starter cable connections ?
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Disassembled my master window switch, hit it with some isopropyl, followed by a light application of flux with a toasty 150C hot air pass, followed by laser lens cleaning solution and adequate wiping and scraping. Now all my windows work:P.
Secondary fault was the rear left window motor somehow got disconnected so i reattached it.
2008 S60 2.5T Auto (Sold)
