Car Went Limp
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Re: DDM-0049 sets limp home mode?!!
Post by Oka »
EngineeringBloke wrote: 01 Jun 2021, 10:25 I'm not familiar with these screens but in the middle there is a line:
The control module "Limp Home" program has been initiated.
This is under the heading "Substitute Value" for the DDM door control module error DDM-0049.
This suggests that when an error with the door module occurs, the car will be set to limp mode by design. Given this is door mirror, window and perhaps lock control, I do not see why the car should be set to limp mode.
I note that part of the display shows Previous operation cycle which has an error, but Current operation cycle appears ok. Is the issue now resolved?
This might not happen again or could be the first sign of a failure in the door wiring, or the door module.
Just got an accelerator pedal (OEM) to replace.
First, I need to read the pedal function in VIDA to check the current function, before replacing with the new one.
Would you by any chance know of any link of the right instruction in reading the VIDA/DiCE unit? I was looking for a link out there.
Just wondering why a door module would enact a "limp mode"?
Thanks!
