Misfire issues?
marcusmcd
Year and Model: 850 1996
Has thanked: 12 times
Misfire issues?
Post by marcusmcd »
96 850 SW is blowing smoke and running rough. On recommendation, I replaced the catalytic converter, but no change. Took it to an auto parts store to read the codes. Got:
P1310 No DCTC definition
P0303 Cylinder 3 misfire
P0305 Cylinder 5 misfire
P0300 multiple misfire
Spark plugs are good. Any suggestions as to what I might check and/or fix?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
What color is the smoke...black or blue?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1505 times
Been thanked: 3818 times
Move the coils around to see if the misfire codes change. Probably, you need two new ones
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Is this engine coil on plug or distributor ignition system? For coil on plug type check coil grounds and swap around coils to find bad coil. For distributor type, check condition of coil wires and distributor cap.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
Compression test soon, if not next. Did this come on abruptly?
seggs
Year and Model: '09 S60, 04 XC70
Been thanked: 3 times
Post by seggs »
Sounds eerily similar to a problem I had with my 04 xc70 a few months ago. In my case it ended up being a burnt valve. If you going to be switching around the ignition modules anyway, your just 5 spark plug removals away from doing a compression test. You can get a usable on for about $25 on Amazon. Then you at least know it’s not that. I could have saved the cost of 2 modules if I would have done a compression test. Also, check out the wiring to the modules. Mine had large amounts of the wire insulation dried & flaking, which I had to re-wrap.
:mrgreen: Seggs
2009 S60 2.5T FWD 145k
2008 S60 2.5T FWD 140k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
Has thanked: 1850 times
Been thanked: 1710 times
Coil packs on plugs did not come into use until 1999 models. Car will be a distributor with plug wires to the plugs.
Check the plug condition. Also remove the distributor cap and check for damage/wear to distributor cap and rotor. Also look for oil in the base of the distributor.
Turbo or NA?
Check there is not oil running into the top of the engine from a blocked PCV system.
Also check the plug wires have not been trapped under the cover near the distributor. They can get picked and short out.
Let's try the simple stuff first before we panic about the compressions.
Has thanked: 292 times
Been thanked: 765 times
What Neil said, start there, especially this:
scot850 wrote: 03 Jun 2021, 22:04 ... Also remove the distributor cap and check for damage/wear to distributor cap and rotor. Also look for oil in the base of the distributor.
but all of what Neil said.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
rguzz
Post by rguzz »
I see it a little differently as a compression test is easy, quick and reassuring if the numbers are in spec. If they aren't, well then you have your findings to deal with. It's kind of a make or break point in your diagnostic algorithm, and takes less time than a tune up. When my compression numbers are normal, I can then relax and take my time as I move on. Basically, it's the biggest bang for the buck, if you will. No parts to buy other than finding a tester.
Agreed. Compression test is a good thing to do also. Can be done as part of the checking the spark plug process as the plugs are out anyway.
