2005 XC70 recharge air conditioner
pmurrin
Year and Model: 2005 XC70
Post by pmurrin »
Where is the low pressure port for filling the refrigerant?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
There is none
Fill on the port on the top of the right side Rad support
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
P2 models have the low pressure fitting on the frame rail in front of timing cover. The air pipe from ECM and TCM box is on top of it and will have to be pushed up for the fitting to snap on. Expansion valve systems are tricky to partial charge.
draser
Year and Model: 2005 S60 2.5T
Post by draser »
You may have done this... But I'd check where the leak is also... Signs of oily and dust deposits at around fittings, condenser...
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Just a side note, it's a very common issue with the A/C to stop working when the engine gets warmed up. If that's the case with your car, it's usually the A/C clutch plate that's faulty.
adrian22
Year and Model: s60 2006
Post by adrian22 »
I use to recharge my AC on my old volvo 850 with a kit from walmart(gauge and can+ hoses/comnnector)
now the problem is on my new volvo xc70 nand C60 the port are different and will not fit to the kit connector
How do you recharge the ac ? I want to do it my self
adrian22
dmurphy67
Post by dmurphy67 »
I think you might be trying to connect it to the high pressure port, which is at the front of the engine, and is what I initially tried to do. Those adapters are made to only fit on the low pressure port.
But on my 2005 XC70 the low pressure port is beneath the Power steering & cooling reservoirs, on the left side of the engine as you're looking at it. You might need to move the reservoirs and the power steering hose out of the way to access it. But I was able to connect it and successfully recharge my A/C after doing that.
oragex
Post by oragex »
That's where I refilled as well. Never try to refill with a can on the high pressure side even if you have a special adapter for it.
SVO LOU
Year and Model: 04 XC70, 06 V70
Has thanked: 44 times
Been thanked: 5 times
Post by SVO LOU »
oragex wrote: 26 Sep 2014, 17:22 Just a side note, it's a very common issue with the A/C to stop working when the engine gets warmed up. If that's the case with your car, it's usually the A/C clutch plate that's faulty.
Very happy to hear, son just told me his is doing exactly that, will research and hopefully we'll tackle it soon.
01, 02, 04 XC70, 06 V70
