Hi Volvo drivers gang
So today, i've tried to replace engine mounts...
The one under the gear box, no problem. Everything was a little bit rusty but two forearms later it was in place. The one front, was easy too. I have to order the one under the crankshaft pulley, the rubber plays in the holder. The last one, behind the stabilizer bar, i was unable to pull it out. I didn't want to raise the gearbox to high , afraid to break the seal... If someone has an trick to do this job without danger, I'm interested. Obviously, a french guy on a forum,told me that it was dangerous to lift the GB too high because the seal...
Ohter question, can someone advice me for the siode mountunder the pulley ?
Thanks to you all
Other thing, i picked up some photos of some elements of my dream car, to allow you to give eventually some advice on what to change or not.
Bushes :
Pulley :
Minestrone Party : what's that ?
A last for the road :
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
I should probably change my motor mounts too. I've been avoiding it for years. At the same time I feel I should buy some bluebox ones now before they disappear.
- ZionXIX
So I'm in need of replacement low beam head light bulbs on 2005 xc90. FCP has some basic H11 bulbs listed and some fancy looking HID bulbs. Both come in a bluebox variety. Which ones do I pick?
- Has thanked: 1848 times
- Been thanked: 1710 times
Up here in Canada Volvo uses re-badged Interstate batteries. Only knew that from working in the parts department to help out for a few months. I've found them generally long lasting a reliable.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I found a rear bumper shell in a pretty decent shape at the bone yard the other day. Made my S70 look a year or two younger if I may say so.
BMW 540i 2002
S70 Base 2000
- Has thanked: 304 times
- Been thanked: 517 times
Ouch... I would clean up that wiring!manovlov wrote: ↑19 Jul 2021, 13:36 Hi Volvo drivers gang
Thanks to you all
Bushes :
Pulley :
You can safely raise these engines a good bit, but of course just keep an eye on wires and hoses as you jack it up. Also made you use a wood block or something between the jack and oil pan or gearbox, wherever you are able to lift it.
I had to lift mine a lot to get my rear engine mount out. It’s a little tricky to maneuver back there.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
Hy bmdubya1198
Thanks for your feedback on that rear engine mounbt.
About the wiring, i have no idea on what this relay as to do for a job in the engine bay... I will make more pictures and post them.
Manov
Manov
That is strange, I'm not sure what the relay is for either. Looks like it could be the secondary air injection relay, but it wouldn't be tied into the fan power wire like that.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
I'd put all zero of my pennies on it being for driving lights.
ARB bushings don't look great either, I'd add then to the to-do list. The last pic is just map sensor and ac lines, of it's functional then its fine.
