850 Crankshaft pulley question Topic is solved
Clemens
Has thanked: 473 times
Been thanked: 219 times
Re: 850 Crankshaft pulley question
Post by Clemens »
And remember, to get that 30mm nut off, you basically need an impact gun. It might be possible without one, but I wouldn't wanna try
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
To properly torque the 30mm nut back onto the crank you will need a means to hold the crank from turning. There are tools available to buy or you could make your own. Details available if you need more information.
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Salut Volvolugnut
If you have some plan of o tool to build DIY, i'm interested ...
I spend as much money for tools than for parts, at the end.
:D
Has thanked: 1504 times
Been thanked: 3817 times
Manov, you can put two long M6 bolts into the harmonic balancer holes and then counter hold with a stick or a long breaker bar
Azik09
Year and Model: S70 T5, 1997
Has thanked: 2 times
Been thanked: 31 times
Post by Azik09 »
My way to hold any pulley in any direction using an old belt
Free end of a belt should be placed at any strong part of engine
If my English is bad, please correct me :oops:
manovlov
Post by manovlov »
Azik09 wrote: 22 Jul 2021, 11:45 My way to hold any pulley in any direction using an old belt
Your english is perfect : Vodka !
Manov
Been thanked: 471 times
Post by cn90 »
Salut @manovlov,
The Crank Pulley PN is 1275801, about US $280 for Genuine Volvo.
Even FCPEuro does not sell it ("on back order").
This is simply bc this part lasts the life of the car.
I have been around Volvo forums for > 20 yrs and have NOT seen a single case of rubber separation.
The 2005-2010 Honda Odyssey van Crank Pulley can (but rarely) come apart at the rubber bond.
So, whatever Volvo (or the supplier of the crank pulley) vulcanized the rubber very very well and even after 30 yrs, it still holds up.
Here is a random photo from ebay to show everyone the rubber portion of the crank pulley, this is why
this is also called harmonic balancer. The YELLOW arrows show the rubber cracks, but they are minor cracks.
manovlov
Post by manovlov »
cn90 wrote: 23 Jul 2021, 20:11 Salut @manovlov,
Salut cn90,
Cool to read you. I'm convinced by all minds expressed here.
Again, thanks to all of You.
Manov
manovlov wrote: 21 Jul 2021, 08:34 Salut Volvolugnut
:D
I thought I had a photo of the tool I made to hold the crankshaft, but I cannot find it. It is simple to make. I used about 1/8 x 1 x 1 inch steel angle (but other sizes will work). A Y shape is made from a short length and a longer length. Both angles at the top of the Y have holes to match two of the four holes in the crank pulley. Two opposite bolts of the pulley bolt through the end holes. The two angles are joined by a pivot bolt at the middle of the Y. The long end of the angle is braced against something (or held with a cheater bar) to prevent rotation of the crank while torquing the crank nut.
Kokonradus
Year and Model: 1995 850 10v GLE
Has thanked: 14 times
Post by Kokonradus »
About tightening the crank nut on the engine. I have made a good tool that worked for me perfectly. You just tap the Y ends with 10mm sockets on the pulley screw heads while the middle of the tool has long M10 rod that will stop at the engine mount side and will safely lock the engine so you can tighten the crank nut to180Nm (on 850) with torque wrench according to manufacturers spec.
1995 Volvo 850 2,0 10v NA - Wagon
1996 Volvo 850 2,5 20v NA - Wagon
1992 Škoda Forman 1,3 Carburetor
2004 Volvo Xc70 D5 AWD (Sold)
1998 Škoda Felicia 1,9D LAURINA (Sold)
