foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
foggydogg wrote: 24 Jul 2021, 08:53
bmdubya1198 wrote: 23 Jul 2021, 20:49 Harbor Freight still sells them! Of all parts to clean and reuse, I don't know why people try to push spark plugs so far beyond their service life.
Then again, this is Abscate we're talking about...
Gasoline got better, oil improved, and computers took over from points and mechanical advance distributors and carburetors - all the stuff that could carbon up your plugs before their allotted time in service. It was mostly the DIY crowd for cars, but for airplanes it is still common practice.
https://www.aircraftspruce.com/catalog/ ... 4kEALw_wcB
And that particular piece of shop equipment is in stock, ready to ship !
And only $1858.00 !
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
I'm continuing my legal medicine session with my 850. I removed the passenger seat and the backrest no longer reclines. This thing weighs the weight of a dead donkey. I also took out the passenger side carpet for a deep cleaning: humidification with cold water - washing - sodium bicarbonate sprinkled and left to act for an hour:
carpet driver side.jpg (145.06 KiB) Viewed 415 times
You can see how the power acts... Incredible. I don't know what the last owner has thrown on it, i do prefer not to know obliviously :mrgreen:
Electric trick :
Here, it's the big mystery : there a cable that goes from the back of the alternator to the relay, it seems to be the cable that comes from this part (clear blue arrow) :
Air Conditionning Unit.jpg (116.64 KiB) Viewed 415 times
The relay HELLA (SAAB), has got the big red cable that comes from the main harness. Why did they do that ? :
tricky Harness.jpg (256.94 KiB) Viewed 415 times
tricky Harness part 2.jpg (208.24 KiB) Viewed 415 times
tricky Harness the end.jpg (115.21 KiB) Viewed 415 times
I don't feel really comfortable wtih car wiring, becaise essentially i don't know well that stuff. But... (wait a minute...) but i have wirng harness. So i will see basically the cables colors tomorrow with the scheme, it should be okay.
Rear window wiper : there is power. So, i'm nearly sure it comes from the pump in the engine bay...
Cherry on the CaKe : i found this, hidden under a lot of dirt :
Power seat issu :
I have to look for a tutorial, i think our Bud Robbie DiY has done one somewhere...
Power seat wiring.jpg (231.53 KiB) Viewed 415 times
I suppose that the white plug is the part squared in red on the board, am I right ?
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
That diagram you posted is the AC compressor. Specifically it looks to the be the wire for the clutch magnet.
manovlov
Post by manovlov »
ZionXIX wrote: 24 Jul 2021, 12:33 That diagram you posted is the AC compressor. Specifically it looks to the be the wire for the clutch magnet.
Why to go pick power on this cable ??? I don't understand.
manovlov
Post by manovlov »
Which fastener for this hose ( there's another one on the other side) to screw on the "screw" on the second picture ?...
Fastener missing.jpg (152.3 KiB) Viewed 408 times
manovlov
Post by manovlov »
the next big challenge is to re-dress the the roof sky. Any suggestion for what material to use ?
I also ask by which side to begin, to know that i have a sunroof ?
Manov
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
Did the rear shock mount fight today.
Why did Volvo decide to use fasteners 3 times longer than they need to be in open mounting holes?
1 came out, 2 stopped part way and one broke...
With the 2 that stopped part way and the broken one, I turned them back to where the threads were smooth, but still had enough room to chop the tops off with the angle grinder. I then I ground a groove in the top and used a screwdriver to screw them out the bottom of the hole.
One was too boogered up to turn with the screwdriver, so I had to drill it out. The weld nut also went with it, so I put my riv-nut tool to work again and installed a new threaded insert.
Mounts are all nice and fresh now.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I've wanted to get a riv nut tool, those are really helpful to have. I could have used one on my car for the charcoal canister mount when I snapped off the welded nut.
Interesting, I've never had an issue with those bolts though. I always just zip them out with an impact, they come right out.
Chuck W
Post by Chuck W »
bmdubya1198 wrote: 24 Jul 2021, 20:57 Interesting, I've never had an issue with those bolts though. I always just zip them out with an impact, they come right out.
Could be due to your location. Doubt you see much salt/brine on the roads in the winter.
An impact might've helped, or it could've just busted the weld nuts off. There's no need for so much extra fastener sticking out in the elements like that, however.
bmdubya1198
Chuck W wrote: 24 Jul 2021, 21:40
Yeah, I’m spoiled with my southern cars lol. Given the location of the bolts, they probably take on a lot of spray from the road. They could be a little shorter.
