- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
I recognize that dash. It never rattled or squeaked in my 18 years. Looks like the slight heater core leak has gotten... a bit worse. Which parts are you getting to reuse?
FireFox31
- Has thanked: 304 times
- Been thanked: 517 times
Under an hour, not bad!
- Has thanked: 1498 times
- Been thanked: 3810 times
The mounts were ever so slightly cracked, now epoxied
The heater core blew up - you were not long for a major incident before your Hyundai Interaction.
Got your Message - you need a 2000 AT gear plastic and I think I have that - different from the stick of course.
- FireFox31
More specifically, I need the large center console black plastic pieces. In the attached diagram, they're parts 13 (coin tray), 4 (base around shifter), and 17 (behind parking brake). Since it's out, I'd love to have my old steering wheel. I can trade you my leather one and my damaged versions of any parts you provide if you'd like. To save you time, I could come remove the many trim parts that I need. Heck, I could help you remove the engine, trans, and steering rack and you could send the husk to scrap.
- GR-71680.jpg (79.21 KiB) Viewed 734 times
FireFox31
I might have accidentally pulled of the last piece of stubborn roof with Shaggkira and a tow strap. This allows one to deduct both miles driven and capital depreciatioof the “ portable Swedish de roofer”
See your tax Attorney for details.
Awesome….
Awesome….
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
Automatic gearbox starting to kick out of gear when first or reverse. Highly annoying. Sometimes issue stays away long time...
Last time checked i somehow had too much of gearbox blood in. Need take some of it away..
- RickHaleParker
- Been thanked: 958 times
Problems are at the extremes ... Check the cable for worn bushings or anything that creates slack. Cable could be stretched preventing one from reaching reverse or first reliably.
For some reason, I can't find high-quality black plastic center console parts on the Internet. Perhaps you need to go to the store some good one.
Life it's soooo beautiful
employee monitoring
employee monitoring
