So today my dirver's side head light on my 94 850T Volvo wagon, (low beam only) went out. As i was taking off the wire harness, with great difficulty and a little gentle prying, i found that on the inside of one side of the harness, where the light connects to, the inside was burnt and brown, this burntness continued on the outside of the harness. So... i replaced the bulb and checked the fuses, none of which were blown, but still no light will emit from the drivers side only; high and low beams do not work on the drivers side. The passenger side light work fine high and low beam.
Any suggestions? I assume that i will have to replace the wireness...
94 850t Wagon Headlight issue...
volvomoose
- Year and Model: 855t 1994
1995 850 Turbo Wagon (180k)
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
The connection is bad...you'll have to change the entire piece out that has turned black.
volvomoose
So that means.. cutting and splicing another (new) harness?
Thanks for your help!
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
1996 850 NA Wagon
1996 940 Wagon
1986 240 DL
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
There have been a few posts about burnt holders.
The consensus is to replace both the bulb and the burnt socket. I have done just that on my wagon.
First check to see that you are getting power to that drivers side socket, if no power, solve that issue first.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
MadeInJapan
When you say harness, you mean at the plug for the headlights right? If so, then yes. If you mean, all the way back to the car's wiring harness, closer to the larger fuse box, then no. You should be able to source these parts used at a junk yard or call the guys at www.erievolvo.com
Same thing happened with my fog lights...only solution was to splice the wire to a new connector that was basically burnt up inside and would only make intermittent contact for the fog lights to come on.
- Year and Model: Many Volvos
- Been thanked: 76 times
Even if it is new, change the bulb along with the connector. Once the connections carbonize it is grief forever.
- 35 Replies
- 6684 Views
Last post by bmdubya1198
- 1607 Views
- 1233 Views
- 15 Replies
- 2749 Views
Last post by j-dawg
- 20 Replies
- 4211 Views
Last post by Spacebiba
