I've recieved my FCP order today and watched a bunch of videos on changing the timing belt, pulleys and water pump. I am wondering if one should remove the crank pulley or not? It seems some people do and some don't. I really want to make sure that I can ascertain that nothing moves when I change it and will mark everything and take lots of pictures along the way.
Also would it be worthwhile to make sure the CVVT hubs were set up correctly on the last timing belt change? The CEL light has been on pretty much continually since I owned the car and I plan to clean and test those solenoids at some point. I really don't want to be posting a thread "timing belt change and now car won't start" next week.
Any advise would be appreciated! Thanks.
Changing Timing belt this week, any tips? Topic is solved
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 113 times
- Been thanked: 262 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 604 times
Read the errors with DiCE/VIDA and post them here.
Remove the aux belt pulley. Air or electric impact wrench would do the large nut w/o need for counterlock. Mark every pulley + belt in a couple of spots with white corrector fluid or something alike, remove the belt, replace the water pump, transfer marks from old belt to new, install it. Use large paper clips to hold belt in place on camshaft pulleys while you're working in crankshaft pulley area.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
Remove the dust guard beneath the crank pulley, the geared pulley itself can remain in place, diesel models require removal of the pulley but gas models are fine leaving it in place. It sounds more complicated than it is.Blacklab467 wrote: ↑03 Sep 2021, 17:50 I've recieved my FCP order today and watched a bunch of videos on changing the timing belt, pulleys and water pump. I am wondering if one should remove the crank pulley or not? It seems some people do and some don't. I really want to make sure that I can ascertain that nothing moves when I change it and will mark everything and take lots of pictures along the way.
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
Lots of light. I use a "miner style" headlight as well as a mechanic separate light. Remove coolant bottle definitely. Crank pulley is not hard to remove and as said above it may not be necessary unless you need to get to the seal behind it
Also I use whiteout or white paint marker to make the timing marks more visible
Good luck
Feld
Good luck
Feld
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
leave the crank pulley and big nut alone, remove the front engine mount (two bolts) and torque mount and raise the engine, this will give you some extra room to do the water pump. Check the VVts for play, especially wobble at fully counter-clockwise is a common failure a volvo tech told me.
- Blacklab467
Just got done doing the timing belt, water pump and idlers and a new serpentine belt. No surprises, I followed the A-1 Auto and FCP Euro videos, I did not remove the crank pulley and had no trouble getting the belt behind the pulley, took about 3 minutes. The only trouble I had was that my car has a T-50 torx for the serpentine belt tensioner instead of a 14mm which makes it a bit of a chore for one person to get that belt on. My T-50 socket was too long to get a ratchet on so I had to turn it with a 9mm wrench but it wasn't a big deal.
I marked all the notches with white paint as seen in the pictures. A big help for confidence is shown in one of the pictures; I marked the position of the old belt with paint and held it over the new one to ensure that the cam positioning was correct.
Finally I flushed the coolant system and refilled with the Blue Volvo coolant at 50/50.
The whole job took 3 1/2 hours working slowly and not drinking beer. Skill level: easy to moderate.
2003 XC 70 (sold)
- Blacklab467
I know! I really wanted to concentrate on getting the timing marks lined up and getting the timing belt tensioner set up properly. After I did the "smoke test" and it ran fine I cracked open a beer while finishing the final assembly.
2003 XC 70 (sold)
Sufbug
- Year and Model: 1998 V70
- Has thanked: 2 times
- Been thanked: 2 times
jonesg wrote: ↑03 Sep 2021, 18:51Remove the dust guard beneath the crank pulley, the geared pulley itself can remain in place, diesel models require removal of the pulley but gas models are fine leaving it in place. It sounds more complicated than it is.Blacklab467 wrote: ↑03 Sep 2021, 17:50 I've recieved my FCP order today and watched a bunch of videos on changing the timing belt, pulleys and water pump. I am wondering if one should remove the crank pulley or not? It seems some people do and some don't. I really want to make sure that I can ascertain that nothing moves when I change it and will mark everything and take lots of pictures along the way.
YUP! remove that dustguard and the belt will go on.
I had to wiggle it around a plastic piece too, but that was kinda loose already. The pic is of the metal piece.
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
