Just need to verify when you guys replace the timing belt on your P2's.
My V70 last had it replaced on Jan. 2013 with 107k miles.
I now have 169k miles on her. Am I still OK?
Timing Belt replacement
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 151 times
- Been thanked: 4 times
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 113 times
- Been thanked: 262 times
I think the interval is 105,000k for regular conditions, that number will be in your owners manual in the glove box. I just did mine yesterday and it had 95000 miles and no cracks or noticeable wear. Generally recommended to do the idler, tensioner and water pump on the second timing belt change. Mine had the originals in there with 286,000 kms and they appeared to still be serviceable. I changed them all with Volvo OEM to be sure.
2003 XC 70 (sold)
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
if in doubt, change the belt. Ive also changed belts after major seal oil leaks, probably over careful but i dont want to risk it. Also stick with the Volvo branded kit, the pulley and idler is made by Ina so you can save money buying from them but no one knows who makes the belt.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
Belt is most likely made by Gates.
INA aftermarket is a holy crap for the past 3-5 years. Crappy bearings, crappy casting... I sure hope Volvo puts something better in its blue boxes, like INA made in where it has been made a decade ago.
Mr. Detail
Sorry but can someone fill me in on the letters for "INA" and what they stand for?
- BobbyC777
- Year and Model: V70 2.5T, 2004
- Has thanked: 15 times
- Been thanked: 5 times
I have a 2004 V70 (FWD) 2.5T. My Owner's Manual says the timing belt interval is 120K miles for the 2.5T engine on AWD cars. Why would AWD vs. FWD make any difference? The 'regular' engine (non-turbo) interval is 105K miles.
There are also comments that certain engines (with engine VIN codes 39 & 64) have a 150K interval.
And another note that Engine VIN code 59 has a 120K interval.
(see link to Maint sched at end of post}
My engine code sticker has 3 numbers:
Can anyone help clarify this?
Thanks!
Bob
https://volvo.custhelp.com/app/manuals/ ... NBJTIxJTIx
- 6900631
3386469
B5254T2
Thanks!
Bob
xHeart
- Year and Model: 2.0/3.2
- Been thanked: 115 times
This will help little with your VIN https://www.volvotechinfo.com/index.cfm ... vinDecoderBobbyC777 wrote: ↑17 Sep 2021, 11:52 I have a 2004 V70 (FWD) 2.5T. My Owner's Manual says the timing belt interval is 120K miles for the 2.5T engine on AWD cars. Why would AWD vs. FWD make any difference? The 'regular' engine (non-turbo) interval is 105K miles.
My engine code sticker has 3 numbers:I am not sure which of these specifies the Engine VIN Code.
- 6900631
3386469
B5254T2
Thanks!
Bob
- BobbyC777
Thanks, xHeart. I was looking at the various engine #'s on the timing cover sticker & block rather than digits 6 & 7 of the VIN. Those digits for my car are 59. Thanks for setting me straight! According to the maint. schedule my interval should be 120K miles. But there is a lot of controversy about 105K vs. 120K despite what the manual and schedule say. At a minimum I have 25K miles to make a decision as to what to do. Thanks again!
