Went to the Horseshoe Beach Volvo races……
My T5 won the crown……
- Has thanked: 1505 times
- Been thanked: 3818 times
- Has thanked: 927 times
- Been thanked: 1000 times
OK. You have to explain these creatures to a land locked Okie.
volvolugnut wrote: ↑12 Sep 2021, 14:04 OK. You have to explain these creatures to a land locked Okie.
https://en.m.wikipedia.org/wiki/Horseshoe_crab
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
Simple docile creatures that witnessed the extinction of the dinosaurs and whose blood has magical properties that can not be reproduced.
- ZionXIX
For the past few weeks my dashboard lights have not been working when the headlight switch is turned to the "on" position. So figuring out my speed at night has been super fun. Anyway I decided to tear apart the switch and clean it up. A little cleaning with light sanding and new dielectric grease has fixed the problem. Free fix if anyone needs it. Warning, the plastic housing will break when trying to free the tabs. Here are some pics of the before and after.
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
Added more stuff to the engine. Now just waiting for the head gasket and some miscellaneous other parts.
I'm getting closer. The anticipation is killing me.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
What is wrong with the tank so that you will replace it? I decided to replace mine because it looks brittle in the area that you photographed, but nowhere else.
FireFox31
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 620 times
- Been thanked: 143 times
This car has spent 18 years in saoudite Arabia. So each time I can, I play security. The goal is to keep it as secured as possible. When I will be retired, I don’t wanna specially do hard job on it.
- Has thanked: 292 times
- Been thanked: 765 times
98 V70 with 293k: Changed the fuel pump in a parking lot 1700 miles from home. Had to buy a voltmeter otherwise I had what I needed with me.
Thanks abscate for the tech support!
FYI this car was throwing recurring P0172 codes for a few days before the pump completely died. Changing the fuel pump got rid of the code.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
