Has thanked: 1505 times
Been thanked: 3818 times
Spray paint with LiquidSteel (tm) and you are done!
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
How will that be as strong as the original metal part? I'd feel more comfortable milling a crude yet effective one out of metal at a machine shop.
FireFox31
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
FireFox31 wrote: 14 Sep 2021, 11:03 How will that be as strong as the original metal part? I'd feel more comfortable milling a crude yet effective one out of metal at a machine shop.
That's just a model, I believe. The final product will likely be made of aluminum/steel.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Potential marketable product here for the engine mount.
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
bmdubya1198 wrote: 14 Sep 2021, 12:02
It's an input model that'll be the basis of the actual mount made from 1/4" steel plate. It doesn't fit EXACTLY, which is the reason I built it. I need to space out the lower bolt holes another 1/16" or so front to back.
I have to get another argon bottle for my MIG welder and I can build the service piece.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
Nevada1906
volvolugnut wrote: 14 Sep 2021, 12:26 Potential marketable product here for the engine mount.
Possibly, might even be a set - who knows? Right now, I need a way to physically mount the engine in the chassis and this is it.
Has thanked: 1850 times
Been thanked: 1712 times
Excellent work and best of luck getting to the finished part. Maybe a new side-line job here? Wouldn't be the first to do so on MVS taking a hobby to a full time job!
Nevada1906
ZionXIX wrote: 13 Sep 2021, 20:35
Nevada1906 wrote: 13 Sep 2021, 20:26 Here's a tip for anyone who wants to take a run at swapping an S60R engine into an 850: At least one engine mount doesn't line up.
This is the front mount from the 850's B5234T. As you can see, not only is the bolt pattern wrong, but the bolts themselves won't fit the old mount. Luckily, there's a solution.
I took some measurements for a new mount, built it in Rhino and output the file to the resin printer.
And voila. This is a quick-and-dirty template for the actual 1/4" welded steel engine mount, fully compatible with the stock cushion mount.
And it fits nicely, too.
Nicely done sir! Cant wait to see the final product.
Thanks! Always nice to know people like my work.
Nevada1906
scot850 wrote: 14 Sep 2021, 19:24 Excellent work and best of luck getting to the finished part. Maybe a new side-line job here? Wouldn't be the first to do so on MVS taking a hobby to a full time job!
Thanks!
Of course, I've gotta test it first. This is a Rev 1, after all.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 337 times
Post by Chuck W »
The stock P80 RN front engine mount does work (99-00 S/V/X70 (and I assume the 99-04 C70)) in this instance. If you can find one.
As someone who built and sold custom motor mounts (other applications) for 15 years, I applaud your work. If you're planning a weldment as a final piece, you can use your printed example as a basis to build your weld-jig.
