Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Installed one of the oil cooler coolant lines, as well as the front engine mount yesterday. Today, I buttoned up the top end and got set up for the timing belt installation. I have to epoxy a few breaks in the front cover first.
You don't need to use any special tools to install the upper half of the cylinder head. The bolts (43 of them) are long enough that if you place the cams as close to TDC as the engine will let you, you can tighten them down in sequence and you'll be fine.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
These engine rebuild posts are really helpful as an anatomy lesson in our engines. It looks similar to my 2000 V70, so its helping me get more familiar with the components. For instance, I never knew about the hard coolant line coming off the coolant pump until seeing these pics. Thanks for them.
FireFox31
Nevada1906
Most of the turbo and all of it's coolant and oil plumbing.
Lots of, "Oh that's right - THAT'S what that part is!" as I sorted through the pile.
Nevada1906
FireFox31 wrote: 19 Sep 2021, 17:16 These engine rebuild posts are really helpful as an anatomy lesson in our engines. It looks similar to my 2000 V70, so its helping me get more familiar with the components. For instance, I never knew about the hard coolant line coming off the coolant pump until seeing these pics. Thanks for them.
You're welcome. I'm having fun with this engine, but it's good when I can help a fellow car guy in the process.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
Nevada1906 wrote: 19 Sep 2021, 19:31 Most of the turbo and all of it's coolant and oil plumbing.
20210919_170628.jpg20210919_170653.jpg20210919_170727.jpg20210919_170734.jpg20210919_170745.jpg20210919_185413.jpg20210919_191215.jpg20210919_194027.jpg20210919_194146.jpg
This is so awsome. Its a real shame you dont have a 3d scanner handy to digitize this work of art.
FireFox31
Post by FireFox31 »
Nevada1906 wrote: 19 Sep 2021, 19:34
All of your posts would be valuable all in one place instead of mixed in here. If you're ok with it, could the moderators pull them out into their own thread? It's a valuable collection of visual info, far better than a blurry parts diagram.
FireFox31
Nevada1906
FireFox31 wrote: 19 Sep 2021, 20:08
Fine with me. Have at it.
Nevada1906
This is the car the S60R B5254T engine I'm building is going into.
1995 854 Turbo. 253,000 and change miles on the chassis. I'm pretty sure the head gasket in the B5234T blew somewhere around 230,000 miles, but only became a real smoker around 250,000. Still drove fine though, but Virginia does inspections...
ZionXIX
Post by ZionXIX »
Nevada1906 wrote: 19 Sep 2021, 20:38 This is the car the S60R B5254T engine I'm building is going into.
Very clean
Nevada1906
Finished assembling the turbo tonight. If you're going to build it piece-by-piece on the engine, make sure to attach the blowoff valve before you rotate the compressor housing into final position. Otherwise, you won't be able to get to the three bolts.
I used the wastegate actuator to determine the final clocking of the compressor housing.
And with the exception of the second hose on the oil cooler, the hot side is done.
