850 Glove Box Latch Repair Topic is solved
This topic is in the MVS Volvo Repair Database » Volvo Glove Box Repair - The Saw Method
Has thanked: 1505 times
Been thanked: 3818 times
Re: 850 Glove Box Latch Repair
You know a post is good when the thread dates from before smartphones...
Well done, Lee.
Franz47
Year and Model: 850 TDI VAN 1997
Post by Franz47 »
A few days ago I repaired the broken part. I drilled a 2,5 mm hole at the place where the broken pin was, cut a 3 mm thread into the hole. Then I inserted a piece of a a screw without head and fastened it with epoxy glue. Some white grease on the moving and sliding parts and works as before. Then I practiced opening it with the credit card strip. Worked fine. I also had purchased the repair kit but will keep it in case my repair brakes down. The original part had lasted 25 years, will see whether my repair will last longer .....
Has thanked: 1848 times
Been thanked: 1710 times
Very creative and well done sorting it. Even smarter having a back up plan of new part and way to open the glovebox should the repair fail again.
850forum
Year and Model: 1995 850 turbo wagon
Been thanked: 6 times
Post by 850forum »
Franz47 wrote: 24 Sep 2021, 10:43https://www.motor-talk.de/videos/handsc ... 47092.html and today it did the trick for me without destroying anything. Cut a 2 cm strip of a credit card or similar, bend one end, then introduce it into the slit between lid and box at a distance of 22 - 22,5 cm from the left end of the lid. After a few attempts it worked for me like shown on the video. You have to pry the strip really deep so it goes in between the hook and the bracket. Once it slips into the correct place, the lid opens immediately. You can then see then how the strip is stuck in the lid-locking mechanism
Of course you can't keep the plastic strip in the glove box...
Console box, might get tossed out.
Maybe duct tape it on the bottom of the glove box/dash area.
NEVER OPEN THE HOOD !!!
