I need to program a fob for my other 2001 XC; found this instructions.
https://www.keylessentryremotefob.com/b ... emote.html
If you have a red security light in the dash of your vehicle, you will be able to manually program this remote.
To manually program this remote:
1. Ensure that all doors, hood, and trunk are closed.
2. Insert key into ignition, turn key to position #2 and back to off at least 5 times
in ten seconds.
3. The LED indicator should start to flash, leave ignition on.
(a) Which is the LED indicator?
(b) Leave ignition on at position II?
4. Once indicator starts you have 15 seconds to program remote.
5. Press the lock button on the remote.
6. The indicator LED lighting for about 2 seconds acknowledges the programming.
(a) "LED lighting for about 2 seconds" What does this really mean?
Thanks.
Fob Programming
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
Fob Programming
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
Hi Oka
3a - the Red LED in the center of the dash
3b - yes, position 2
6 - it will be on for longer than a momentary flash
I've done this, but its been a while.
Hope this helps!
Let us know how you fare.
Jonboy
Hope this helps!
Jonboy
- Has thanked: 292 times
- Been thanked: 765 times
Waiiiiit a minute ... I thought that for 98+ it was dealer only for programming a fob? I am certain that is true for a 98 (P80), did they make it easier at the P2 switch?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1505 times
- Been thanked: 3818 times
You get a million dollars but Someone you don’t know gets a P0455 code
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 44 times
Thank to the OP for sharing. Real money saver if it truly works. Unfortunately, it doesn't work for my 2001 V70 T5. One of my original keyfobs has a bad unlock button so I needed a replacement but was not going to go to a Volvo dealer due to cost. I tried this procedure with a few junkyard replacements, all with new CR2032 batteries. I can't get the security system to flash the red light after 5-6 ON-OFF key sequences. I can get the security system to work normally (lights when locked) with my original "good" keyfob. Anyone else get this procedure to work on a 2001 V70?
Thanks for input/feedback.
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
93SCMax wrote: ↑20 Dec 2021, 09:38 Thank to the OP for sharing. Real money saver if it truly works. Unfortunately, it doesn't work for my 2001 V70 T5. One of my original keyfobs has a bad unlock button so I needed a replacement but was not going to go to a Volvo dealer due to cost. I tried this procedure with a few junkyard replacements, all with new CR2032 batteries. I can't get the security system to flash the red light after 5-6 ON-OFF key sequences. I can get the security system to work normally (lights when locked) with my original "good" keyfob. Anyone else get this procedure to work on a 2001 V70?
Same here. I do believe my UEM is bad & that could be contributing to the inability. My LED works when the car is locked.
Sure would be convenient to get a fob working with the car. Definitely not going through Volvo off that though.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
I e never done a fob on a P2 but the chip key is definitely VIDA
- 2915 Views
Last post by jtp
- 3939 Views
Last post by stephansvolvo
