What is the difference? You sure its not just different labels in front of the light bulb?
Are V/S/C70 DIM units all the same?
- RickHaleParker
- Been thanked: 958 times
Re: Are V/S/C70 DIM units all the same?
- Has thanked: 1847 times
- Been thanked: 1710 times
I used to know the answer to this. They do have different part numbers ( one digit different). I also can't remember if all the warning lights are in the same place. I'll try to remember to take a picture of the CDM at POSII with the ignition key and then you can compare to the US version.
- RickHaleParker
I could compare it to my 1998 C70. I am not finding anything in the owners manual that indicates a difference between US and Canada warning lights.
I have posted my warning lights below:
If I recall the lower 'missing 3' on LHS are (L-R) : Rear foglight, ETS, SRS
Here is a US version on this Youtube:
- RickHaleParker
[quote=scot850 er 'missing 3' on LHS are (L-R) : Rear foglight, ETS, SRS
[/quote]
Center second left is not used. Bulb warning, N/U , ETS, SRS.
Not seeing any physical difference other then the overlay.
Yes my front fog light bulb is out and I did not take the pictures before the SRS light went out. Tricky getting a good shot with the LED conversion.
I am sure you could use a US PCB. The Canadian Chips and light bulb overlay will take care or the rest.
[/quote]
- Has thanked: 1505 times
- Been thanked: 3817 times
Found this one from my 1999 T5
viewforum.php?f=1
We get check engine light in the Southern Canada you guys get the cool little motor icon.
Only VIDA can check the Cruise light, strangely enough.
viewforum.php?f=1
