The NEW (2018) BLOOPERS AND BLUNDERS THREAD
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Ouch!
volvodork
Year and Model: 2001 X/C 70
Been thanked: 3 times
Post by volvodork »
Installing a rebuilt 351 Windsor into my son-in-law's 1994 Ford F-150 (replaced the blown 302 motor) and would crank but no-start. Went round and round banging my head trying to figure out what I'd missed (I've rebuilt a couple Ford motors before) even pulled out distributor a couple times to check if 180 out, firing order, etc., finally found that I had forgot to plug the electronic distributor wire into the harness. Fired right up!
THEN....was falling on it's face/low power; idled great. I had checked the timing (10deg BTDC) or so I thought. Truck runs a whole lot better when you don't have the timing at 10deg AFTER top-dead-center.
Sometimes you have to put aside all of your "experience" and and not "over-think" things when trouble-shooting.
bmdubya1198
Yeah... I tend to overthink things quite often! I've gotten much better at avoiding those headaches.
motormikeyman
Year and Model: 2004 XC70 AWD
Been thanked: 8 times
Post by motormikeyman »
Replaced my drivers side CV shaft, wheel bearing, brake rotor and brake pads no problemo. Put it all back together nicely. Picked up the tire to put it back on the car and found the dust shield the goes BEHIND the rotor laying under it.... gahhh!
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
Has thanked: 1609 times
Been thanked: 4065 times
motormikeyman wrote: 28 Oct 2021, 11:56 Replaced my drivers side CV shaft, wheel bearing, brake rotor and brake pads no problemo. Put it all back together nicely. Picked up the tire to put it back on the car and found the dust shield the goes BEHIND the rotor laying under it.... gahhh!
You can clip the thin bit with tin snips and reinstall that without redoing all the work
This step is ISO approved by Volvo management..
bmdubya1198
abscate wrote: 29 Oct 2021, 02:06
Actual photo from the development of the 240.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
abscate wrote: 29 Oct 2021, 02:06 This step is ISO approved by Volvo management..
Where did you find a picture of me trying to rebuild a carb??
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
bmdubya1198 wrote: 29 Oct 2021, 09:29
I wish to make a record of this elder abuse with the management.
:P
volvolugnuty
bmdubya1198
volvolugnut wrote: 29 Oct 2021, 10:18
:P
volvolugnuty
:lol:
