2000 V70R for parts, $600, west suburban Boston Topic is solved
NormS
Year and Model: 2018 XC60 T8
Post by NormS »
2000 V70R with 229k miles for parts, Yokohama Tornantes have plenty of tread remaining, spare set of Satelites. Needs windshield, engine oil seals, battery, driveshaft rebuild
Has thanked: 1853 times
Been thanked: 1714 times
Now that is a rare color. I think there were only 13 imported in 2000 to North America!
NormS
Post by NormS »
Venetian red, IIRC. You’re not making it any easier for me to let it go!
i need someone to go through all the pain I have gone through with mine! When you say lots of oil leaks, when was the last time the PCV system was serviced? That will cause many of the leaks along with the oil pipes to the turbo. None of the parts are hugely expensive, but the labor time is the big part.
When I bought mine many years ago, all the seals were supposed to have been done on the engine. Problem was the guy had used aftermarket seals and not a lot of skill. Shortly after buying it all the seals started to go starting with the rear main seal. At that time I did not have the tools to do this type of repair. I took it to the dealer along with a couple of boxes of parts. They swapped the front and rear main seals, cam seals and as it was out I had the transmission main seals done as well as the angle gear seals. The labor charge even at that time was the biggest part of the work. For the most part since then that part of the car has been mostly good.
I really hope this goes to someone with the ability to do the seals themselves. The body damage looks not too bad with a fender and windshield.
Good luck with the sale.
NormS
Post by NormS »
Needed room in the driveway so had to have it towed away. Last seen on a wrecker headed towards a salvage yard in Lancaster MA.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Well, you tried.
Also -> Amazon link
S70Preserve
Post by S70Preserve »
Do you still have the spare set of R wheels for the 2000 V70R?
