V70 T5 2001 camshaft position sensor
Bruceleemad
Year and Model: 2001 V70 T5
Has thanked: 2 times
Post by Bruceleemad »
Hi, I have a code ECM 644a. Reckon it to be cam position sensor, but I cannot find it !! V70 T5 2001. Can anyone help. Even my Haynes manual got it wrong !!   I've got the replacement part, but have trawled the internet for hours and still none the wiser !!
Been thanked: 4068 times
It’s hidden behind the engine mount on the RN engine with VVT.
It’s likely not the sensor but a cam flank problem from dirty oil or stretched timing belt
Bruceleemad
Had a new timing belt 4 months ago, this problem cam up not long after. Could it be that the timing wasn't done correctly ? I will change the camshaft position sensor and the crankshaft position sensor anyway, as they're not that expensive ( if I can find them ) and then hopefully my surging and rough idle may get sorted. Gut tells me I'll end up replacing the etm though. ☹️
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
it might just be loose, fixed mine that way.
Yep, someone didn’t read the VIDA entry and set the cam up one tooth off. Cam flank angle is tight tolerance on P2s,one tooth off will trip the 644A code
