Has thanked: 1505 times
Been thanked: 3818 times
That’s a nasty nasty fuse box
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
wizechatmgr wrote: 17 Nov 2021, 12:03 Steel and brass bristle brushes that had been previously dipped in motor oil were used for the clean. Couldn't find my wheel for my Dremel so it was done the old fashioned way...
I've not heard of that, using oil.
I bought some tiny brass wire wheels for my Dremel - they lasted about 15 seconds.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Going through major withdrawals, having not driven or worked on Sveedy for 3 months, 2 days, so I dropped the fuel tank in order to replace leaking hoses. I wanted all the gas from 3 months ago out of there as well, so I won't have to worry about bad gas when I finally get to turn the key again. Getting worried that I won't remember how everything goes back together when I finally get the engine back from the machine shop.
1999 V70 GLT
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
Sveedy wrote: 19 Nov 2021, 16:52 Going through major withdrawals, having not driven or worked on Sveedy for 3 months, 2 days, so I dropped the fuel tank in order to replace leaking hoses. I wanted all the gas from 3 months ago out of there as well, so I won't have to worry about bad gas when I finally get to turn the key again. Getting worried that I won't remember how everything goes back together when I finally get the engine back from the machine shop.
I would not worry much about 3 month old gas or forgetting how to reassemble. The gas will be fine and you have friends with Volvos.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
It'll come back to you. And if you're second guessing anything, you know who to ask!
Sveedy
Post by Sveedy »
You guys are the best !
Truly !
1999 V70 GLT
Fixed Abbys MCC lights. Well, got them working at least.
If we fully tighten the head into the cable mechanics, pressure on the circuit board turns them off. It’s not the connector or wiring
We just brought the two Torx screws into contact with the head and they work well , now she can see her AC controls at night commuting home!
Bulbs for the Mcc are NLA from Volvo but Mercedes bulbs fit , documented in Evita maintenance thread.
Evita is parked next to a nice neighbor . …
BlackBart
Post by BlackBart »
Sveedy wrote: 19 Nov 2021, 16:52 Getting worried that I won't remember how everything goes back together when I finally get the engine back from the machine shop.
I do this. You disassemble, take a photo, bag & label hardware - it looks simple. Then time goes by, you start back in, and say, How the HELL is this supposed to go back together!?
Has thanked: 1850 times
Been thanked: 1710 times
Yes, although you take loads of pictures, there is never one for the part you just can't figure out from the right angle!
Sveedy
Post by Sveedy »
At least 40 pics, two legal pages of notes, everything bagged and tagged and MVS in my back pocket.
I will be fearless.
1999 V70 GLT
