The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Re: The Resurrection of (10/1998 to 01/2021) Elizabeth 1999 V70T5M56 Cylinder Head Job
Post by foggydogg »
abscate wrote: 22 Nov 2021, 04:47 It’s the big day today. Wish me good weather.
It's gonna blow a Gale in DE later today; hope it doesn't creep North until you've made smoke.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Good luck! The weather sucks down here right now, but hopefully clearing up soon. I have an injector to replace today.
Has thanked: 1497 times
Been thanked: 3809 times
Well got the last bits in....
Exhasut gasket and three bolts
Turbo oil drain line - two small 5 mm internal hex bolts - put the aft one in first, then jog the hard pipe around to start the second using a flexible extension as a screwdriver to work around the pipe, Dont cross thread these puppies
Installed snorkel and the three connections
Installed induction from turbo to bottom of intercooler.
Installed upper rear engine mount , ground strap, route and connect all vacuum and turbo hoses.
Installed water reservoir 27mm oetiker on bottom hose
ADded water - gush gush gush - forgot to connect heater hoses, lost a yellow clip, found in spares box
Cranked for 10 second intervals to get oil pressure light off. Took 2 minutes of cranking in 10 crank/20 rest intervals
Had main engine relay removed to prevent start.
Installed relay
Crank , no fire condition
Fuel at rail
Do not hear ETM whine- click...???
Inspect - forgot to plug in ETM - recified.
Still crank,no fire.
Darkness falls....
Has thanked: 1834 times
Been thanked: 1709 times
Hopefully the darkness is just the day! You have got this a long way. Now you need to go around it like you say and check for any more possible fails in re-connecting stuff. Then check for the usual suspects in terms of fuel and spark.
Fresh head and new day!
bmdubya1198
Time to break out the scanner and see what codes are showing... probably missed something simple. Happens every time!
foggydogg
Post by foggydogg »
With all the big chunks reconnected, it just turns into a routine troubleshooting exercise - best tackled early in the day. We will all chant our most peaceful mantra first thing in the morning, just in case stuff like that might actually help.
I may have been areal dumba$$ and been using my non-chipped key yesterday. That would be really funny.
Sniff of ether this morning to see if we are on the fuel or ignition fork.
Does sniffing ether help you concentrate?
foggydogg
Post by foggydogg »
scot850 wrote: 23 Nov 2021, 08:03 Does sniffing ether help you concentrate?
I wonder if it's cheaper than nitrous ?
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
May be cheaper, but ether does not have the mouth feel of hot coffee.
