vtl wrote: ↑22 Dec 2021, 18:54You can get a replacement wire harness for $90. I installed one like this a year ago.
https://www.ebay.com/itm/234280086036
Thanks VTL.
You know, when I saw the insulation flaking off it didn’t worry me too badly. I thought I already had one of those harnesses, turned out to be the harness that runs over to the ECM/TCM.
Thanks for taking the time to share!
The quality of your harness is ok?
Do you recall if the seller you bought from was from Russia?
For now, since I did not have the harness I thought I had as a backup, I just unpinned, heat shrinked & moved on with life. Hard to believe I hadn’t had any oddities/maladies due to the crumbling insulation.
For ~ 1.5 years I’ve been struggling to find the source of an intermittent loss of boost issue. With the ECM tune I have, my boost gauge will typically peak around 15psi. When the intermittent loss occurs it’s almost like there’s an audible/electronic “click” (akin to a relay) and boost cuts to 7ish psi. Colder temps may be the wind to my back right now, but as I noted earlier (but didn’t make mention of why I did it), I coated every contact point on my CEM, ECM, TCM, etc with 100% DEoxIT and I (knock on wood) haven’t had a single re-occurrence to date.
I am so amazed at how much power this old, unattractive (by millennials/today’s standards) beige station wagon has! It’s crazy that at 310k miles & all original big stuff (engine, transmission, both bevel gears, collar sleeve, etc) this not-so-light AWD wagon can haul so much butt!
I did have a CEM faulty signal in ViDA. Need to spend more time concentrating on it to get to the bottom of it.
