Interesting point! After my 30 minute test drive my daughter took the car to work and did not have any issues either. She will be driving the car home again in about an hour, but for now it does seem like the ignition switch was the culprit. I’ll post again if the problem returns.
Volvo 850 GLT - Electrical power loss while driving Topic is solved
- jmcguire
- Year and Model: 1996 850 Sedan
- Has thanked: 19 times
- Been thanked: 9 times
Re: Volvo 850 GLT - Electrical power loss while driving
1996 850 Sedan
- Has thanked: 293 times
- Been thanked: 765 times
Explain this one to me if you don't mind? I would have said power to the radio is switched not constant and losing it makes perfect sense, but I'm not looking at a wiring diagram when I say it.
By my memory a bad ignition switch gives a dark and quiet cabin when it happens at night, I've experienced it a couple times. Can also give bizarre combinations of dash lights on/off, for that matter.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
The radio ACC power does go through the ignition switch via the X+ overload relay. At least if I'm reading the wiring diagram correctly. So it does make sense that the radio would shut off.
Fuse 7 is the battery power and fuse 32 is the accy power for the radio.
Now why it fully resets and asks for the code is odd, but that could be an issue with the radio or the battery power circuitry to the radio.
The ignition switch is a good thought, especially if the keychain is kind of heavy.
- jmcguire
After a few days of driving, the issue has not returned. Looks like it was the ignition switch. I now have a new one on hand to replace the one I got cheap at the pick-a-part.
1996 850 Sedan
