1999 S70 GLT Sudden coolant loss and power loss
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Re: 1999 S70 GLT Sudden coolant loss and power loss
Sounds like your water pump let go. Take off the timing belt cover and have a root around. Don't run again till you are sure pump is good.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
Or not, closer read and it does sound like a blown hose. Fixit fill it and see what happens. Still you might have screwed up the headgasket. It can blow before idiot lights go on. replace hose and see how it runs, if it is rough running do a compression test or get a test kit from an auto parts store to look for exhaust gases in the coolant.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Also note that when you were low on coolant you could no longer rely on the gage for accurate temperature reading, and an overheat condition may have already been in progress or imminent
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Has thanked: 292 times
- Been thanked: 765 times
Doing both hoses is definitely a good idea. If you bought the hoses online yourself they would be about $60 - 80 each for Volvo branded hoses, about $35 each for aftermarket. The Volvo branded ones are much better ... do you know which your mechanic uses? New O-rings is a good idea but that's high, you can get the whole plastic coupler with all new o-rings from Volvo for $45 (http://www.fcpeuro.com/products/volvo-h ... 70-s70-v70).
The 1.5 hours labor there is no way around, that is book rate for the job.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I have only heard of the hydrocarbon testers that work on a color change basis.
What kind of tester are you using that provides a number like 138?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 1672 Views
Last post by ollebompa
- 15 Replies
- 2856 Views
Last post by wizechatmgr
