When changing the thermostat out why do you have to drain the coolant? I know probably a stupid question but wondering why and what happens if you don't?
Thanks so much,
Sharon
2002 V70 75kmiles. When changing thermostat, why.....
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
There are ways around doing a total drain (for instance, draining the coolant reservoir, clamping the major hoses, etc.) but you will need to drain some. If you don't, you will have a pretty large coolant spill from the thermostat housing which will make a mess. Right under the housing are belts, some sensors, etc. You just really don't want to get them wet with the coolant if you can avoid it. If it has been 2 years since the coolant was replaced, when you change your thermostat is an excellent time to go ahead and do a flush and put new in.
- 607 Views
Last post by Foursightho
- 12 Replies
- 1696 Views
