- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
duke1 wrote: ↑16 Jan 2022, 10:09This is a bit hard to understand; do you mean they mount outboard of the headlight assemblies? Parts diagrams over here show two item numbers, 9151655 and 9151656, but it seems to be an issue regarding how the blade fits the arm. Maybe a picture, or a GB part number would help ?Clemens wrote: ↑13 Jan 2022, 13:38hi its the wiper arms not blades,the blades i can get its the arms/stalks that i need and cannot find any new in right hand drive as the lhd are mirror image and do not fit correctly,i did find a used drivers side on ebay but remains to be seen if its any better than mine,i blame poor info on the r and d car parts website which fails to tell you the parts are for lhd onlyduke1 wrote: ↑12 Jan 2022, 11:28 also the front windscreen wiper arms are knackered and seem impossible to obtain the correct one! i looked all over the web in the uk and ended up using r and d car spares in sweden not realising there lh drive only suppliers so now stuck with arms that dont fit and cost more to send back than they re worth!,cheers
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
foggydogg wrote: ↑16 Jan 2022, 14:58hi its the front windscreen not headlamp,rh drive are mirror image of lefthand drive arms/stalks not blades,there the easy bit!duke1 wrote: ↑16 Jan 2022, 10:09This is a bit hard to understand; do you mean they mount outboard of the headlight assemblies? Parts diagrams over here show two item numbers, 9151655 and 9151656, but it seems to be an issue regarding how the blade fits the arm. Maybe a picture, or a GB part number would help ?Clemens wrote: ↑13 Jan 2022, 13:38
hi its the wiper arms not blades,the blades i can get its the arms/stalks that i need and cannot find any new in right hand drive as the lhd are mirror image and do not fit correctly,i did find a used drivers side on ebay but remains to be seen if its any better than mine,i blame poor info on the r and d car parts website which fails to tell you the parts are for lhd only,cheers
- foggydogg
My apologies, what did Churchill say about our two countries being separated by a common language ?duke1 wrote: ↑12 Jan 2022, 11:28 hi all today i did an gearbox oil change on the 855 it was not real dirty looking and no metal bits around however the gears are stiff when you first start driving and loosen up to normal after a few miles i know the linkage is via cable can anyone tell me if these can or should be lubricated ? also the front windscreen wiper arms are knackered and seem impossible to obtain the correct one! i looked all over the web in the uk and ended up using r and d car spares in sweden not realising there lh drive only suppliers so now stuck with arms that dont fit and cost more to send back than there worth!![]()
the breakers here are crap and lazy if you cant remove a part with a machine they wont remove it and so much good stuff is wastedright hand drive parts seem harder to find.peace
I have no idea what would be involved with buying from Skandix after the BrexDivorce,
https://www.skandix.de/en/spare-parts/b ... t/1037337/
https://www.skandix.de/en/spare-parts/b ... t/1037338/
Both listed for RHD cars.
Bob Morton
- Year and Model: 1998 S70 T5 SE
- Been thanked: 8 times
Cleaned a C70 brace to get ready for painting.
- Dirty3.jpg (351.38 KiB) Viewed 471 times
- Clean3.jpg (300.62 KiB) Viewed 471 times
- Has thanked: 304 times
- Been thanked: 517 times
Just cleaned the one I picked up, just not as thoroughly!
- Has thanked: 1500 times
- Been thanked: 3812 times
Don’t put that on the R, I can barely see you in the rear view as it is
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
Nice, I love cleaning old stuff up, and making it like new again. My project was along the same lines, but a bit smaller.... I just scrubbed my oil fill cap, and installed a new gasket
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- foggydogg
That's my method, too, do at least one thing to the car every day. Unfortunately, in my case I have a small herd to wrangle.
But I'll be quicker around the corner!
