car key locked/stuck in ignition slot, can't be removed
EliseandFredBrink
Year and Model: 1997 Volvo 850
Post by EliseandFredBrink »
Our car key is locked into the ignition key slot and can't be removed.
This is after car battery ran down completely while sitting through cold spell, and then was recharged fully, and car started fine when key was inserted and turned, and drove fine.
Radio has failed to come on , even with the correct factory code for theft-protection was .entered
Now the key is locked into the key slot, and can't be removed.
-Tried turning off everything, wiggling everything, turning wheel, changing drive selection with hand grip, wiggling the button in the drive selector handle.
Any suggestions?
Fred Brink
Has thanked: 1504 times
Been thanked: 3817 times
The gear selector lever has to be firmly in park to release the last little turn of the key to POS 0, where it will come out. Have a good look at the key and see if it is stopping just short of KP 0
These things do gum up and get stuck with age, cold weather exacerbates this
Has thanked: 292 times
Been thanked: 765 times
Make sure the shift knob is fully seated on the shaft - pop the knob downward with your palm. And make sure the shift lock override button is not stuck down.
If none of the "easy fixes" work then keep in mind: There is a metal piece for the steering lock mechanism that breaks off and jams up the key mechanism, a stuck key (or one that will not turn) is a common result of this. It gets stuck because the tumbler can't turn all the way back to position 0. Much more common with S/V/C70 than with 850 but can happen. Fairly easy fix with a dremel viewtopic.php?f=1&t=67531
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1846 times
Been thanked: 1710 times
On the radio front, do you know if it may have been swapped or are you 100% sure it is the original?
If the code does not work it may have been swapped so you will need the code for the current one. If you try to enter a code 3 times wrongly it locks you out. There is a procedure to un-lock but it take the car being left with the ignition on if I recall for a long time, or removing the radio and sticking it in the freezer. That last one may be just my bad memory.
You can remove the radio and contact a dealer. There is an ID stamped on the radio that you need to get to them and they can find the code for that head unit. There is a code finder but I think that may be only for the original radio matched to your VIN #.
jeringo
Year and Model: 1998 S70
Post by jeringo »
My 98 does that in cold weather overnight even running ok. I have used a hair dryer set on it for several minutes and this frees it up every time. Some very tight tolerances must be shrinking and keeping it locked. Heat might help.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Could be a similar problem except yours won't allow your key to return to the "0" position for removal.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Here's a good post in a good thread about the key being stuck in the ignition. A second good thread and a very technical post about it.
Ensure the shifter button is all the way out and the shift lock override button is all the way up. Spray around both with a tiny amount of silicone spray. I recently had to remove the center console (four bolts, not hard) to push up the shift lock override button from the bottom. Pulling it up wasn't enough.
FireFox31
SirBrickWagon
Has thanked: 7 times
Been thanked: 11 times
Post by SirBrickWagon »
scot850 wrote: 12 Jan 2022, 14:53 On the radio front, do you know if it may have been swapped or are you 100% sure it is the original?
on my car the radio code was on top of the head unit in sharpie when pulled out slightly. it's on both of my radios, i sure as hell didn't write them on. maybe it's the same for this one
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
I have done that with any radios I pulled as I have got the codes from the dealer and at this age it is unlikely anyone wants to steal them! Easy enough to pop the radio head unit out enough to get the code if I forget!
