Tail Light no longer reflects - appears white from scratches
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
Is there a proven way to sand/buff the tail light assembly to make it look red again? I can see that the white color seems to arise from the myriad scratches. At night, walking by the parked car with a flashlight, its hardly visible at all. Compared to the one on the other side which is a few years old replacement part (original cracked). Or pricing a replacement (right side).
NEVER OPEN THE HOOD !!!
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
hi there are products for the cleaning of the lenses but if there bad then best replaced my 855 had cataracts and no amount of remedies worked,got set rear lights for£40 from breakers not worth the wasted time,im told it is uv damage from using wrong plastic remedied on later models i think after 96ish,headlamps do the same thing but some baking soda and elbow grease improves this,good luck850forum wrote: ↑28 Jan 2022, 00:09 Is there a proven way to sand/buff the tail light assembly to make it look red again? I can see that the white color seems to arise from the myriad scratches. At night, walking by the parked car with a flashlight, its hardly visible at all. Compared to the one on the other side which is a few years old replacement part (original cracked). Or pricing a replacement (right side).
- Has thanked: 927 times
- Been thanked: 1000 times
Taillight lens can be improved the same way as plastic headlight lens, If badly discolored, start will 2000 grit paper, then 3000 grit, then polish with headlight refinish. However, you may just decide to replace the lens.
- 331 Views
Last post by azureblue
- 1224 Views
Last post by WarbirdPilot91
