2001 S60 Dents, Scratches, and Tears
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
WarbirdPilot91
Year and Model: 2001 S60 Base
Post by WarbirdPilot91 »
Hello Gang,
In my quest to refurb my recently bought used S60, I am seeking some interior/exterior body help. Below are some pics with descriptions/ideas. I've heard the heat gun/dry ice thing may work. Any insight or tips you could give would be AWESOME. Thanks, all! :)
Dent on rear drivers door. Right where the curve starts.
Dime/Penny sized dings along both sides, some with minor scratches in them.
Scuff of plastic rear bumper, behind rear wheel.
Deep scratches on rear pax door.
Was de-badged (looks like some cheesy logo was slapped on these.) Buff?
Rear door fabric de-laminating from door panel. Spray glue?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 604 times
Post by vtl »
Heat gun/dry ice trick works only on Japanese foil-made cars. Volvo is a main battle tank of the roads, a drakkar, one solid piece of metal, whose fate in the event of crash is to kill everyone around and save lives of those inside. Our fathers told us that at the end of time - Ragnarök - Naglfar ship will sail to Vigrid, and it will be shaped as a 850 wagon. It is extremely hard to get rid of a dent even with straight access to it through the hole under interior panel. Check that out:
If avoiding the dent specialist is a goal, I'd live with the dents, use touch paint to hide light scratches and clear coat for heavier ones, then clean the whole car thoroughly, dry and apply Turtle Wax Shell, twice. In fact, that's what I do every year, before winter, with wife's aging V70.
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
First a good wash and degrease. I use palmolive dish cleaner that strips all wax off. Tiny scratches I use a pointy brush - art supply store - and clear to go along the scratch. Deep scratches I try to build up layers of paint then wet sand and buff. May still be visible when done. Emblem on hood - wet sand with 1000, 2000, 3000 then buff. I use McGwyar cutting compound 85 grit and a cheap buffer from Harbor Freight. The clear on Volvo responded well to this, but it takes several passes. I used the wool bonnet and foam pads that I had fron another kit. Problem is the touch up paint is a few shades darker due to car discoloration. Scratches showed on mine.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
WarbirdPilot91
vtl wrote:Heat gun/dry ice trick works only on Japanese foil-made cars. Volvo is a main battle tank of the roads, a drakkar, one solid piece of metal, whose fate in the event of crash is to kill everyone around and save lives of those inside. Our fathers told us that at the end of time - Ragnarök - Naglfar ship will sail to Vigrid, and it will be shaped as a 850 wagon. It is extremely hard to get rid of a dent even with straight access to it through the hole under interior panel. Check that out:
draser wrote:First a good wash and degrease. I use palmolive dish cleaner that strips all wax off. Tiny scratches I use a pointy brush - art supply store - and clear to go along the scratch. Deep scratches I try to build up layers of paint then wet sand and buff. May still be visible when done. Emblem on hood - wet sand with 1000, 2000, 3000 then buff. I use McGwyar cutting compound 85 grit and a cheap buffer from Harbor Freight. The clear on Volvo responded well to this, but it takes several passes. I used the wool bonnet and foam pads that I had fron another kit. Problem is the touch up paint is a few shades darker due to car discoloration. Scratches showed on mine.
AWESOME info, thanks a ton! The little dings, I can live with. But, the big ones gotta go. I will try the plunger technique, and if that fails, I'll find a dent guy.
I DID manage to fix the rear-doors fabric! 8) Little spray glue and plastic vinyl applicator did the trick!
