98 V70 cable release help
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
I’m not sure if this is the place to post this. I am 2.5 hours from the closest salvage yard, I didn’t have the time to travel this that’s 5 round trip. Im in the SW WA area coast.
I am in need of a hood cable release. New ones are 60.00 which I can really afford either.
My ask, is there anyone with an extra or in close proximity to a pick n pull that could help me out in this?
Please DM me if you can help.
Thank you all!
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
Has thanked: 1505 times
Been thanked: 3818 times
I can pull one my parts car , Jane Bond.
It’s a 2000 , so check comparability.
It’s free, courtesy of the FDPP and FireFox’s generosity
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
I had a slightly hard time opening that hood for about five years. Required pulling the latch, then trying to lift the hood (free from one side's clip?), pulling the latch again, then lifting it the rest of the way. Maybe it was the snow bank I gently hit, nudging the hood slightly off kilter. Or maybe the cable stretched a bit. Something to be aware of when reusing it.
FireFox31
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
FireFox31 wrote: 01 Feb 2022, 17:30 I had a slightly hard time opening that hood for about five years. Required pulling the latch, then trying to lift the hood (free from one side's clip?), pulling the latch again, then lifting it the rest of the way. Maybe it was the snow bank I gently hit, nudging the hood slightly off kilter. Or maybe the cable stretched a bit. Something to be aware of when reusing it.
I had one that stopped working. I sprayed some lube in there at the latch mechanism, and it has worked since.
All U.S. market models.
All running and on the road.
I can push some lube through this one before shipping. Let me know here or PM, please
stephansvolvo
abscate wrote: 01 Feb 2022, 23:19 I can push some lube through this one before shipping. Let me know here or PM, please
Did you get my message?
Stephan
98 S70 GLT
73 IH Scout ii
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
For what it's worth, the hood cable is probably fine. The issue with having to pull up on the hood is due to the latches, I believe. I added bumpers to mine to eliminate that extra step of the process.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I had this annoying thing too with one of my latches on the S70. I dont think the latch itself gets bad but the wire stretches a bit over time?
Anyway, I loosened the bolts for the latch and pushed it downward as much as I could. There is a little play there to work with. Release mechanism started working again after that.
BMW 540i 2002
S70 Base 2000
bmdubya1198
Yeah, you kind of have to adjust it over time. Between moving the latch downward, and adding bumpers to the existing ones on the hood to put a little more pressure against the latches. It probably is a matter of the cables stretching, now that you mention it.
