P80 P2 Coolant pipe o-ring & install 976045 Topic is solved
Has thanked: 1502 times
Been thanked: 3817 times
Re: P80 P2 Coolant pipe o-ring & install 976045
Do you mean pull the pin on the tensioner or pull the tensioner off the car?
It does pay to set everything to the not-TDC marks before doing any timing belt or water pump work
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm talking about locking the cams in the front with plywood / zip-ties etc. I installed NA cams so I can't really lock them in back because of the difference in timing. I'm not taking the belt off, just moving it to the side enough to get the pump out.
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Yeah, I would still recommend setting it to the marks. Keep in mind you'll also have to clean off the gasket from the pump, so you'll probably want the belt out of the way. Might not need to take it all the way off, but it's better to be safe and go ahead and set it to the alignment marks.
Sveedy
Post by Sveedy »
Since it never really ran, other than for 10 sec, and never got warm, I think the gasket will come right off. All the others have so far.
1999 V70 GLT
You don’t need to lock the cams on a non VVT CAR. Set the crank to the timing mark , take the belt off, remove water pump
Nasty business with water pipe
Check cam timing marks
Reinstall belt , two full revolutions of motor , check marks , pull the pin
Sveedy
Post by Sveedy »
Received an O-ring today, but won't have time to install till this weekend.
It would appear that the tapered end makes a world of difference. You can certainly see why the straight cut pipe would be hard to install and be pron to nicking the O-ring.
1999 V70 GLT
Sveedy
Post by Sveedy »
Looking at my pic, it looks like there is a small nick in the new O-ring, but it's just something with the pic.
Ring is in perfect condition.
1999 V70 GLT
Sveedy
Post by Sveedy »
Installation went beautifully !
I can say that the O-ring can be installed without pulling the water pump. As long as the end of the pipe is tapered. I also slipped the O-ring on the pipe and left it that way for a couple of days to help stretch it some. When I was ready to install, I took it off the pipe and popped it in the recess. I say popped because that's what it pretty much did. Fit the recess snugly all around, unlike the first O-ring.
A little lubricant, and the pipe slipped right in.
If the center mounting tab on the pipe had been flipped around 180*, then the pipe could be removed without taking off the exhaust manifold and turbo. Would have been a simple thing to do during design phase. That one bolt makes you have to pull all of that other stuff just to remove the pipe.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
In defense of designers everywhere, it is much easier to draw with pencil or computer a bolt attachment, than it is to actually put in the bolt. Nearly 50 percent of designers have less than average experience.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
Sveedy wrote: 12 Feb 2022, 16:12 Installation went beautifully !
Fantastic, that's great to hear!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
