2001 V70XC - Starting with Blackstone Oil Report
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: 2001 V70XC - Starting with Blackstone Oil Report
Post by vtl »
xHeart wrote: 07 Feb 2022, 13:04 Thank you VTL!
Is this the valve stem seals you're referring to for a 150k miles service? If so, then, our Robert DIY channel has a four-part step-by-step video on valve stem seal replacement -- I'll look through it for the assessment of task.
Yes. If you go that way - clean the guides as best as you can, degrease and press new seals dry, only lube valve stems lightly. Many folks have had their new seals coming off, because oil gets between valve guides and the seals. Cylinder head has a lot of oil in and around valve tappets area, that's a lot of cleaning work. If seal comes off, the oil consumption would be even greater than with the old worn seal.
Also don't use any glue, most of them degrade under high temperature and serve as a lube.
Or you can wait for the burnt valve and do the job on the bench, with a clean and dry cylinder head =)
