P2 brake bleed nipples, Brake Bleed Screw is ATE-390354 Topic is solved
Has thanked: 1505 times
Been thanked: 3818 times
Re: brake bleed nipples
...and here is the28 grams of prevention
When you do your Volvo recommended %two year brake fluid flush 😃😃😃 replace all the bleeders with new ones every other flush, or every flush in salty, crusty , wintry areas.
This will add $30 to your flush bill, but that’s worth an hour of labor to me, at least.
Could also ask FCP if you can replace two every other year And return two as wear items.
Here’s your part number. 30665014
And link
https://www.fcpeuro.com/products/volvo- ... escription
Been thanked: 472 times
Post by cn90 »
Actually, I add a bit of penetrant fluid (PB Blaster etc.), maybe one drop at the junction of the bleeder and the caliper and let it soak in beforehand. Never have a problem with them.
jonesg
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
don't forget the rubber cap with a bit of grease over the bleeder.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Post by XC70Rider »
The bleeder screw size for both front and rear calipers are M10 x 1.00 x 35mm (length). The fronts have a 11mm hex head while rears have a 10mm hex head. They will fit all 4 calipers. Just width, thread pitch, and length is all that matters.
Bleeder torque...it’s too low to do accurately with a torque wrench. I’m not even sure I have ever seen a valid spec I believe
One source says you torque the bleeder the same as the brake hose - that’s wrong
You want to clean it thoroughly so that the taper forms up smoothly on the corresponding taper on the caliper
Once it contacts , 1/8-1.4 turn more, no more
If you are using a 6 inch ratchet handle, it’s too tight
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
abscate wrote: 10 Aug 2020, 06:48 Bleeder torque...it’s too low to do accurately with a torque wrench. I’m not even sure I have ever seen a valid spec I believe
I expect you mean 1/8 to 1/4 turn after contact.
My thought is 1/8 turn past contact is enough.
jonesg
Post by jonesg »
knock them loose with air hammer.
Post by cn90 »
- Since ATE makes brake calipers for Volvo, BMW, Mercedes, VW, Porsche etc. etc.
- Volvo PN 30665014 has a dimension of L = 36 mm; thread M10 x 1.
Current price is ~ $9.00/each!
- BMW 34116768018 is basically ATE-390354 and also has a dimension of L = 36 mm; thread M10 x 1.
Current price is ~ $3.39.
- If anyone in forum buys ATE-390354 and installs it sucessfully in the Volvo, please report back.
This is bc if you refresh these bleeders x 4 every 8-10 yrs, it is good to have a source for identical item for much less.
BONUS: the ATE-390354 includes the rubber cap.
The Volvo PN above does not include the rubber cap!
Post by cn90 »
My 2007 S60 2.5T 115K Right Front brake caliper bleed screw is broken with about 2 mm sticking out.
Has anyone tried this youtube trick: drill a hole so the reverse tap can drive it out?
Heat that thing up nice and hot, several times , then try a sharp vice grip to easily out
