2004 V70 2.5T, $1750, Lakewood CA
exshavier
Year and Model: 2004 V70
Post by exshavier »
Time to let my V70 go. Been a pleasure to drive and fun to work on. But now it's got a likely blown head gasket and I don't have the time nor skills to attempt that fix. My dad gave me the car in 2013, and it's been my main driver since then. I've done most of the work on it myself, except for the big things.
2004 V70 2.5T FWD
YV1SW59V742361135
193,500 miles
Condition/Work done on the car
-Runs well despite the head gasket
-Recently did a compression test, and all cylinders had good compression
-AC and heater working great
-Just changed the battery
-4/5 ignition coils changed (Delphi); one still original
-No check engine light on currently
-Transmission rebuilt about 8 years ago; transmission cooler added
-Radiator replaced about 6 years ago
-Replaced O2 sensor and fuel pressor sensor within the last 2 years
Issues
-Likely blown head gasket, detected exhaust in the cooling system
-Consumes quite a bit of coolant
-Front passenger strut is quite noisy
-Cassette player not working
-CD player intermittently works, sometimes need to pull CDs out with needle-nose pliers
-Sun roof cover is jammed open
-Sun roof won't open, moves a couple inches and then makes a crunching noise; tilt function still works
-Front tires are wearing unevenly, extra wear on the inside
That is to say, it'll need a bit of work, but it still has life left in it. If I had the time, I'd do it myself. Thanks for looking!
