hi all ive developed a strange problem and wondering if anyone else had the same issues
my driver side dipped bulb went
then my indicator turning right activates the interior light
my drivers side window swithch controls the passenger side
the indictaor bulb on drivers door flickers until the door is locked manually
drivers door wont lock via remote
driver door module lights flicker
drivers door lock clickiing
electrical issues Topic is solved
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 23 times
- Been thanked: 127 times
Great that you posted you symptoms and the resolution, this will really help. If you have any photos, please post.
There are a couple threads around that note some door wire compromises, the failure is pretty much always the driver's side door (unless vehicle is heavily used as taxi, even kid taxi) and it's caused by repetitive flex right at the crimp interface in the connector body in the door itself. Poor design but it is what it is. Good to pull the boot and check upon occasion, yours is a 2005 but time will catch up with the rest of the model years.
Resolution is normally a removal of the pin/socket itself and a new pin re-crimp or a new pin re-crimp and a short insulated extension. Pretty common problem over time and rear turn signals are sometimes affected as well (they tie to the mirror signals at a point).
For sure any description of photos of the issue and the repair would be greatly appreciated for folks to reference.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
No need for pics. There’s a lot of pics floating the internet for the door wiring issue.
Congrats on fixing the issue and appreciate the update!
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- 11 Replies
- 5028 Views
Last post by oragex
- 471 Views
Last post by brookelander
