940 crank, no start... options?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
nmontague81
Year and Model: '96 854, '93 945
Has thanked: 2 times
Post by nmontague81 »
940 turns but won't catch. Was driving along when car shut off, dash lit up, and would not restart. Have so far replaced: cap, rotor, spark plugs, cables, fuel pump relay, fuel pressure sender, crankshaft position sensor, and MAF. Inline fuel pump is working, battery is ok. Car still does not start.
What did I miss?
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Do you know if you have spark at the plugs? Do you know if you are getting fuel out of the injectors? Do you know if you have leaks in the air intake downstream from the MAF?
Any of these can be your problem. Identify the problem before you replace more parts. Throw parts at the car will likely only deflate your wallet.
nmontague81
Problem solved: water pump gaskets were cracked, allowing coolant to flood the engine and bog it out. USE ONLY OEM or OE GASKETS.
Has thanked: 1505 times
Been thanked: 3817 times
Oooof
