1996 850 engine revs without accelerating or shifting gears Topic is solved
EB53
Year and Model: 2013 XC60
Been thanked: 3 times
Re: 1996 850 engine revs without accelerating or shifting gears
Post by EB53 »
Will do, thanks
EB53
Post by EB53 »
New piece of information. Was out driving and engine started revving to 3000 at 15 mph. If I jiggle the gear shift lever while in drive, without shifting to 3rd, the RPMs dropped to 2000 and I was able to accelerate normally. Even small movement of the gear shift while in drive, is enough to bring RPMs down. Does this suggest that the lockplate for gear shift is loose? Any other thoughts? Thanks.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
There were two times i have had this issue with two separate causes. One was caused during normal driving and it was due to the transmission fluid being too low after a drain and fill. It would drive perfectly normally but at times you would push the petal and it would rev but do nothing. Filling the fluid to the proper levels fixed that.
A second time occurred when my ignition coil went out on the highway although the car died and i replaced the ignition coil.
Suffice to say it does sound like a transmission issue although it might just be fluid.
2008 S60 2.5T Auto (Sold)
EB53
Post by EB53 »
Thanks. Transmission fluid is near top line in reservoir. and fluid is clear on dipstick. Car doesn't die, so probably not ignition coil. I agree it is likely a t'mission issue. Really just takes small jiggle of shift lever for RPMs to drop back to 2000.
EB53
Post by EB53 »
For those who followed this discussion, the problem has been fixed. Turned out the PNP switch was not working properly. Replacing the switch returned the engine to normal acceleration. It wasn't a problem with the throttle body, throttle position sensor, or transmission fluid levels, none of which fixed the problem when addressed. There never were any codes nor did check engine light come on. Thanks for the various suggestions.
Has thanked: 1505 times
Been thanked: 3818 times
Thanks for follow up post!
Has thanked: 1850 times
Been thanked: 1710 times
Glad you found your solution! Well done!
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Since the exact same thing happened to me today as well, I might give that a try
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
