Key turning issue Topic is solved
Has thanked: 1839 times
Been thanked: 1709 times
Re: Key turning issue
It could be either your key is excessively worn so the car is seeing you trying to start it with a wrong key, or maybe the tumblers are sticking.
Also try moving the transmission to N to see if it makes a difference. It could be the car is not seeing it is in Park so may be a PNP switch issue or adjustment.
Has thanked: 1501 times
Been thanked: 3812 times
Big shot of silicone spray into the tumblers might help free them up. Otherwise you are bracing yourself for a new lock assembly.
I did and documented one here last fall I think. Link to it will be in my maintenance thread under “ Lady Evita”
Link to maintenance Forum below
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Is graphite supposed to be used in lock cylinders, not a liquid spray? For my home door locks, I put "4 In 1 Oil" on a key, insert it in the lock a few times, and it works. But I seem to remember reading that graphite is better.
FireFox31
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I bought my S70 with a bad tumbler. Lived with it for years until I almost got stuck in some God forgotten place. Bit the bullet and bought a new assembly. Old one is easy to remove with a Dremel, just some vacuuming required afterwards.
BMW 540i 2002
S70 Base 2000
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
Well I'm a bit embarrassed to admit it, since I probably should have tried it when I was first having issues with the lock, but graphite lube for the win! From the first spray the problem mostly disappeared, a little twisting of the key and now it's completely solved. Thank you!
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
Hey, sometimes we can all overlook the simplest solutions! Glad it was that simple!
kallekula
Post by kallekula »
Woho you saved $300+ !
BMW 540i 2002
S70 Base 2000
