Has anyone tried or used these motors? They come with a PTC inside. I have also seen companies selling just the end caps on Aliexpress which have the thermal resistor. Again anyone tried those just for the resistor?
https://www.aliexpress.com/item/1005002 ... c22b533-19
or
https://www.aliexpress.com/item/1005001 ... c22b533-55
or
https://www.aliexpress.com/item/4000719 ... -recommend
Does anyone know the resistance value of the PTC resistor?
Thanks,
P80 door actuator motor
- Has thanked: 2200 times
Why don’t I pull some off Jane Bond and send up the Calgary Express?
Thanks for the offer. I have some spare actuators and a couple of new ones, but may still buy some of these motors in the spirit of group learning. I have done the copper wire fix for now, but living in Canada where these can freeze solid I prefer to have the motor protection in place. The 'R' is now mostly going to be used for summer transport (both days!!) up here and put away for the winter unless the darn thing gets sold which it clearly is asking for! Grrrr!
At $20 CDN each with shipping, a lot cheaper than $350 from the dealer with a discount! Probably worth a try.
I’m coming up to,Calgary before I croak to get the R hammered onto full boost somewhere.
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
I too would be curious on this. My 98 S70 needs three of the actuators fixed.scot850 wrote: 24 Apr 2022, 16:32 Has anyone tried or used these motors? They come with a PTC inside. I have also seen companies selling just the end caps on Aliexpress which have the thermal resistor. Again anyone tried those just for the resistor?
or
or
Thanks,
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
Well hopefully you won't be croaking for a long time! But yo know you are always welcome and if the damn car is still here and running you are welcome to take it out for a hurl!
I have ordered 2 of the motors and 6 of the end caps with the resistor in them. If/when they arrive I will try fitting these to actuators I have and see how they work. I'll update as/when it happens.
I have linked my other thread on what lube to use on the motor drive and gear wheels.
viewtopic.php?t=99933
- C1ph3r
- Year and Model: 1999 V70T5
- Has thanked: 32 times
- Been thanked: 7 times
Neil the timeliness of your posts regarding this issue is serendipitous. thanks for pointing me over to this from my post.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
- C1ph3r
looking forward to seeing how this goes. as soon as i get mine apart i'll be ordering up some motors as well. did you have any luck on matching the motors up with any suppliers on ebay? when i did my lexus i found the motors in sets of 4. also, does the worm gear come off by chance to transfer over to a motor that may not have the gear?scot850 wrote: 25 Apr 2022, 19:44 I have ordered 2 of the motors and 6 of the end caps with the resistor in them. If/when they arrive I will try fitting these to actuators I have and see how they work. I'll update as/when it happens.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
- 1121 Views
- 915 Views
Last post by sleddriver
- 779 Views
Last post by volvoAgX
- 2386 Views
Last post by kahl
- 21 Replies
- 10558 Views
Last post by RickHaleParker
