P80 door latch actuator internal lube?
Has thanked: 2215 times
Been thanked: 1853 times
I am in the process of swapping the failing thermo-resistor with copper wire. Motor fires up fine with a 9V battery.
Before I glue the case cover back on, I see what looks like petroleum jelly or the likes in the area of the center of the white plastic cogs. What can I use and how much should I use. Can I use lithium or silicon grease?
Thanks,
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
scot850 wrote: 24 Apr 2022, 16:16 I am in the process of swapping the failing thermo-resistor with copper wire. Motor fires up fine with a 9V battery.
Thanks,
A dab of either would work well. If you already have the silicone use that but I have never had problems with white lithium grease. Curious, do you have any pictures of your motor repair? I have to do this to 3 of my door locks on my 98 S70.
Pat Callaghan Jr.
98 S70 GLT
I did not but then there are a couple of good YouTube how-to's including from our good MVS friend Robert Spinner:
The next one shows a bit more detail with more information on the motor part itself
Hope this helps!
Also check the other thread I have open on the possible replacement motors or even the thermo-resistors that come with end caps. I would take the resistor out the end cap and throw it away and try it on your own motors. The motors themselves seldom fail, it is almost always the resistors.
I looked up on plastic or nylon gears and grease. They say not to use Lithium or petroleum grease on plastic and nylon gears as it makes them swell and degrades the material. Silicon or high temperature white grease (?) are recommended, although the general understanding is the nylon is self lubricating so does not need grease, with the exception if they have shafts they rotate on.
Why is nothing simple! LoL!
Has thanked: 1614 times
Been thanked: 4078 times
Get some silicone grease at the plumbing section of your local home store. Often used on valve seats there
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
abscate wrote: 26 Apr 2022, 03:38 Get some silicone grease at the plumbing section of your local home store. Often used on valve seats there
Permatex Dielectric "Tune Up Grease" is silicone, too, as is AGS Silglyde.
I've also seen it in little packets at the checkout at Orielly Auto.... from Versachem, I think. Probably for a 1$, so maybe more now that prices are up.... maybe Canadian Tire/Princes Auto do the same?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
I actually found a small tube of silicon grease as used by plumbers for 'O' ring greasing or cassette installs on tap units. It is ideal for all I need for the job.
I put a small amount on the brass worm drive and either end of the shaft where it sits in the plastic housing, as well as removing the upper drive wheel and putting a little grease on the shaft and re-fitting it.
Re-fitted the cap after pre-cleaning the case where the 'hat' and the case meet with rubbing alcohol and then used 4 or 5 small dabs of super-glue to hold the 2 parts together. Clamped with plastic spring clamps to hold together.
Finally cleaned around the join and and sealed with silicon.
I did not want to use too much glue in case I have to re-open the casing.
I re-installed as per Roberts video and tested the outer latch as suggested. All was good so connected the battery and tested with the fob. All seems good!
I will decide if I will remove and fit one of the motors I have on order which have the built in protection.
