Recommendation for running back up camera in s70
BenjaminGG
Year and Model: 1998 S70
Post by BenjaminGG »
I recently installed a 7 inch double DIN head unit in my 1998 S70, I also purchased a back up camera and want ed to know if anyone has done this before and what the best route to take to the trunk is? I want to keep the wire as hidden as possible as the car is in great shape considering it was garage kept by my great grandparents until I was given it in 2018.
I try to keep it immaculate, I only replaced the head unit because of the Cassette player dying on me.
I tested the backup camera by wiring straight to the battery and it worked fine for that.
I know I'm going to have to tap into the power off of the reverse lights to get power, and the camera wire through the license plate light or drill a small hole somewhere on the trunk door...
I don't have much knowhow on cars or wiring, just what I can find from reading forums and. watching on youtube.
Any and all advice would be helpful, thank you in advance.
Has thanked: 2215 times
Been thanked: 1853 times
My camera I fitted to my 2003 4Runner is on a bracket that mounts behind the rear licence plate and due to the design of the tailgate it is fairly well hidden.
Does your 98 have the trunk key lock installed? Some of the later cars just have a dummy which you could use. Either that or go to a junk yard and see if you can find another latch assembly and gut it, drill a suitable sized hole in the back panel and install the camera in there?
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Recommendation? Sure.
Every time I want to use my backup-camera-equipped daily driver (2016 Focus ST), I walk around it once to make sure nothing's behind it. Then I don't need a backup camera.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
I ran my wires for other things under the plastic carpet hold down/door trims. As Volvo did. You will see when you pry those off.
Has thanked: 1614 times
Been thanked: 4078 times
Nevada1906 wrote: 28 Apr 2022, 16:55 Recommendation? Sure.
After > 50 years of driving , it’s hard to adapt to using a camera for reversing.
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
driving in reverse ?
