850 -93 automatic only drives in reverse
Elle66
- Year and Model: 1993 850
Looked around online and ut seems like this is the speed output sensor. But the only site I can find the sensor on is parts geek. And they don't seem to ship to Sweden. Does anyone know where you can buy this sensor?
- Has thanked: 2200 times
What is the part number you are looking for? The part number cross-reference in you r link earlier when I look it up shows it is fitted to 96-98 cars ad one website show it fitted to 2004 model Volvos.
Did you try Volvo or gcp.se for the part?
Thanks,
Thanks,
Elle66
Found it on volvo! Thanks!scot850 wrote: 04 May 2022, 09:22 What is the part number you are looking for? The part number cross-reference in you r link earlier when I look it up shows it is fitted to 96-98 cars ad one website show it fitted to 2004 model Volvos.
Thanks,
Wich of the 2 speed sensors controls shifting. The input or output sensor? Anyone have a clue?
I really don't know. I would suggest logic says the input controls the transmission shifts. I would expect the output would control the speedometer read out and the ABS signal.
You may have to ask Volvo or a transmission expert to confirm.
Good Luck!
Good Luck!
Elle66
Thought so too, cause the input sensor is much easier to get ahold of and way cheaper.scot850 wrote: 05 May 2022, 12:12 I really don't know. I would suggest logic says the input controls the transmission shifts. I would expect the output would control the speedometer read out and the ABS signal.
Good Luck!
Will try to check with volvo.
I really hope it's the input tho because it's so much easier to reach, lol
Thanks!
I hope so too!
