2011 C30 T5 shudders under load at high speed, check engine light on
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
stheemka
Year and Model: 2011 C30
Post by stheemka »
Have a 2011 C30 T5 with just over 120K, has always run fine, but noticed check engine light on a couple of weeks ago. Only run issue seems to be that it starts from a stop fine, goes up through the gears fine, but once you are rolling along 50-60mph and give it some gas to go up a hill or pass, you feel this shudder. If you let off the gas it goes away, but if you get back on the gas, you get it again. There doesn't seem to be much of a loss of power, and you feel the shutter in the pedal, mostly. Otherwise, it seems to go fine. The check engine light suggests engine and not transmission or engine mount or something like like that, but not sure. Ideas? Thanks!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
stheemka wrote: 02 Apr 2022, 09:41
If you don't have something to pull codes use this combo. Have 4 of the scanner (Amazon Link Broken Again) and the free feature packed and user friendly software:
1) $11.09 Mestart OBD2, OBDII OBD2 Bluetooth Car Diagnostic Scan Tool Auto OBD Scanner for Android Devices
https://www.amazon.com/Mestart-OBDII-OB ... X8V6&psc=1
2) Car Scanner Software
https://www.carscanner.info/
aewoodhouse
Year and Model: 2007 V70R
Been thanked: 7 times
Post by aewoodhouse »
How old are you spark plugs? Worn plugs could cause an engine shudder...
Have you checked the condition of your axles? Shudder under load is often a sign of a worn axle. I drove my C30 with a torn CV boot for over two years and figured I would start to hear that familiar clicking sound when I turn when it was really time to change it. But I never did. What I did experience was the shudder when accelerating - but only once I was up to speed, past 45 mph or so.
2007 V70R
2004 XC70
Past:
2009 C30
1998 S70 - Turquoise 5 speed
2000 XC70
