pcv delete
SirBrickWagon
Year and Model: 1997 Volvo 850
Has thanked: 7 times
Been thanked: 11 times
pcv delete
Post by SirBrickWagon »
need a cheap way to get this car to stop leaking oil all over the driveway, anyone done a PCV delete? just thinking it might be better to have a vent to atmosphere instead of spending the 130 for a whole new system.
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
When it comes time to do mine, I think i'm going to buy bulk hose, and clean up the box.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Post by PeteB »
I spent a lot to do ours and feel the same, that I should have just cleaned the canister.
I think that the car had regular oil changes and so there was not a lot of crap in it.
I did the big hose mod, and agree just use good quality hose.
The worst part is having to take off the intake manifold, but following I think RSPI's
youtube video it went just fine - really not that bad.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'm using a catch can system. It relieves the pressure so you won't push out any seals and collects all of the oil in one place.
Pros - less pressure, and no oily film inside of the intake system.
Cons - Have to empty / drain the can often if the engine is worn. I've noticed that there isn't really anything, other than some condensation, in it with a fresh engine.
1999 V70 GLT
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Sveedy wrote: 31 May 2022, 13:30 I'm using a catch can system. It relieves the pressure so you won't push out any seals and collects all of the oil in one place.
Sveedy, do you have a few details on how you did your catch can setup?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Sveedy
Post by Sveedy »
Well if I could figure out how to download pictures from my new phone/camera on to my computer.....
But mine is much like this one, except not as pretty and made be a local indi shop.
https://www.amazon.com/Universal-Reserv ... B07KK7MGXK
1999 V70 GLT
Clemens
Post by Clemens »
Thank you, that looks nice.
How did you hook it up?
It looks like it vents to the atmosphere.
AFAIK the stock system already has an oil separaror included (the black box under the intake manifold) where oil drains back to the oil pan. The gases are sucked out and returned to the ptc nipple in front of the turbo. Now I think there are catch can setups that delete the stock box completely, while others are added to the existing system.
I'm still not sure on how to proceed, but after replacing the front cam seals this spring, now one of the rear cam seals leaks quite badly. Therefore I suspect that under boost there is too much blowby around the piston rings and I'd like to get rid of that pressure before it pops a main seal.
Summer: 1996 855 R
Donor: 1995 854 10V
Sveedy
Post by Sveedy »
I kept the original separator box, and just ran the additional catch can in line. Yes, it vents to atmosphere instead of going into the turbo, intercooler etc. I'm not sure if you can use it with the stock hose kit. I don't think so. You'd have to pull the intake and replace the stock hoses with 5/8" silicone hose. I'll try to figure out how to get some pictures to clarify.
1999 V70 GLT
Sveedy
Post by Sveedy »
You basically disconnect the large hose that goes from the stock separator down to the valve (PTC ) just before the turbo, and connect that hose to the can. Cap off the PTC. But that stock hose is apx 1/2" and winds it way around from under the intake and throttle body down to the PTC. You could probably cut that hose before it makes the turn, and splice on another piece to run to the can so you don't have to pull the intake. I have the can installed just behind the drivers side headlight.
1999 V70 GLT
