Non-Volvo car chat megathread
- Has thanked: 927 times
- Been thanked: 1000 times
I have seen a lot of nails and bailing wire used as cotter pins, especially on farm equipment.
- BlackBart
- Been thanked: 884 times
Hopefully I won't be plowing any fields in the Alfa..... (If I drive straight)
- BlackBart
Making incremental progress on the Alfa suspension.
Pushed the lower control arm bushings (spherical bearing here) in with a big hammer and big sockets. Slow and careful.
This cool German thread file arrived, and I cleaned up the threads on the control arm spindle so the nut spins on. Cleaned up that dremel cut I made with a tiny fine file.
Lower wishbone together and installed. No cotter pins installed anywhere yet!
I did Ye Olde drill-out-the-rubber, hacksaw the outer shell, and chisel the bushing out of the upper control arm. These are new adjustable-camber arms I bought 20 years ago, but they come with lower quality rubber bushings. The Alfa trick is to put a spherical bearing (same as the lower control arm bushings) in.
Then push out the rubber caster bushing and put a poly bush there. I was thinking how I'd shove this greased poly bush in there with pliers and screwdrivers and end up cutting it.... So I looked around and ah ha, I used the threaded rods used to raise the spring pan, some random big washers, two of those round plates from a HF wheel bearing kit, and it just slipped right in. Then you tap in the steel center sleeve.
Got a new box of driveshaft goodies - U-joints, carrier bearing, support bushing, "Giubo" rubber donut, transmission tailshaft bushings.
Ya think this carrier bushing is done? You think it's original and lasted 55 years?
- BlackBart
<EDIT> I have a site question - all those photos are straight in my file. I post them and half are sideways. When I check on the phone, they all look straight.. ??
- Has thanked: 1502 times
- Been thanked: 3813 times
It could be worse , they could be upside down
- Has thanked: 2652 times
- Been thanked: 1242 times
Phone photos (and any photos) are checked for orientation in their EXIF data, which is included in all modern .jpg/.jpeg files.
If that data is not available, the forum software does its best to orient them correctly. I'd check to see if your phone (or Mac/PC if you export that way) is stripping out EXIF data. It's a very common thing, and requires only a checkbox be checked.
I wouldn't be surprised if some software labeled stripping out EXIF data as "Enhanced Privacy" or somesuch, because it can include lat/long location of photos.
In the past, say about 6 years ago, June had lots of trouble with this, and I found a phpBB extension that looked further than EXIF data set for orientation value. I think it checked proprietary phone (example: Samsung, Apple) data that could also be found embedded in .jpg/.jpeg files in some cases.
This extension worked fine until about a year ago, when an update to phpBB that I dutifully installed caused it to crash the forum, so I removed it.
Since then this fallback has been unavailable, so instead of say 2% orientation failure on photos we've seen roughly double that.
BB and Abscate, what phone brand do you use? Do you upload to MVS threads directly from your phone or do your photos go phone->PC/Mac->MVS?
What software handles the phone images?
- BlackBart
Pics always taken on an iPhone (6SE?), which are saved in Photos, shared on cloud. I’ve only posted pics from the computer, an iMac.
- BlackBart
If I open a photo in preview on my desktop, flip it around 360 until it’s straight again, re-save, it doesn’t seem to do that.
As I scroll up this thread on my phone, they’re all straight.
